Craftsman motor replacement?
/ Craftsman motor replacement? #1
bkenobi
Monroe, WA
NH T1510
My Craftsman DLT LT1000 tractor (917.272201) had just gotten up and running after fixing the sloppy steering when, on it's maiden test drive, the motor let go. I don't know the extent but suffice to say I don't think its worth rebuilding. I specifically picked this tractor because of the B&S Opposed Twin engine it had based on talking to a couple mechanics and reading lots of comments about how reliable it was and was so strong it was the go-to for some tractor racing people. In my experience it was strong until it popped. FWIW, this tractor started with some kind of V-Twin based on the manual but had an Opposed Twin on it when I picked it up.
So, I'm wondering what the options for this unit would be. If I can find a donor tractor with a good motor or just a straight used one, what should I look for in order to make sure it will fit with minimal changes? I know Electrolux made these super modular since the same frame seemed to hold every kind of power plant out there (B&S, Kohler, etc... single cylinder, opposed twin, v-twin, etc). For power, I want to make sure it wont get bogged down and I'm not going back to the B&S single cylinder that always blows the head gasket after a few years. Or, is it better to try fitting a Predator vertical shaft on there?
I'm hoping to get some guidance on what are good options as well as what to avoid. Thanks in advance!
/ Craftsman motor replacement? #2
According to the owners manual for that mower is it came with a Briggs 445777-0129-E1 V-twin OHV engine
Yes that is correct. At some point before i got it the motor was swapped to the opposed twin. So i know it is possible to run with those 2 motors. Just not sure whats involved in changing to another type. The factory seems to have put all kinds on the frame though.
Since the crank case cover plate is cracked down the center, I'm assuming that either it had a mechanical impact or there was a lot of pressure. There is a vent on this model so unless it got blocked somehow I assume it wasn't pressure. The ticking just before it let go says all I need to know I think. I guess I'll pull the engine and look how bad the grenade went off but can't imagine there's much to work with.
The motor that is on my tractor currently (in pieces) is a 20HP 461707-0145-E3. I found a 19.5HP B&S opposed twin 42E707-2631-E3 at the mower graveyard that looked in really good shape. I had the mechanic turn it over and while it didn't seem to have spark, the starter was strong and the motor spun freely. It was missing a carb and coil so he pulled one from a different motor. The carb was pulling fuel but no spark so either the coil was bad or there was something else going on. I ran out of time and they were closing but assuming that motor fires up, anyone know if that's a good match for this LT? It looks the same and I believe in that HP range and year it should be near identical.
Also, Any idea on prices of used motors? The owner threw $200 out there but I've seen many riding mowers given away over the years with good motors so wondering if it's better to just hold off and wait for a parts LT to show up and roll the dice that way. Seems like this is a bit of a roll anyway.
That's what I've been thanking too. But looking at craigslist etc people seem to have gotten the idea some of these are gold plated. That said, if the market supports a 25 year old LT being worth $300-800 then putting in a new engine and sending down the road might make sense.
/ Craftsman motor replacement? #8
Harbor Freight 20hp horiz. Predator is a good engine but $900 or so.
Is it worth anything now as-is?
What's it worth with a used engine?
What's it worth with a new engine?
Me...I'd be looking at a new machine or Craigslist.
I hadn't checked HF yet just read threads and watched some of a few videos. Now that i look, HF doesnt even have an engine that would work because they dont have a big enough vertical shaft. That v-twin is horizontal shaft and yeah, way too expensive to justify. If the bone yard motor runs ill probably put it on and look for a different one off craigslist. This one is fine but the transaxle is a bit questionable. I wasnt expecting to be spending that much on an old mower like this so it's close to going to scrap. Thanks for the input.
/ Craftsman motor replacement? #10
Asking and what they sell for are two totally different things.
Yup thats true. I saw a LT with this same motor that they said was not siezed but claimed needed a new starter listed for $200. I contacted and it had just sold for $200. That assumes they were telling truth. Also who knows about other listings. Its also in perfect condition until you show up and see all the holes rusted through the deck...
It actually looks exactly like i expected. One piston linkage shattered and grenade shrapnel everywhere. It almost looks like a new piston would get her back running. Yeah, not worth the effort though.
/ Craftsman motor replacement? #13
That crankshaft is shot. These engines need oil in them to run for any length of time, plus you have to limit the RPM.
The motor i was going to pick up refuses to spark even with coil from my old engine that was known working. The starter spins it just fine and seems to have good compression (didnt have tester with). Wondering if no spark is something easy that could be fixed or just move on. Not sure what they would take for a scrap motor so may not matter. Any suggestions?
I am also looking at the used market to find a different electrolux option but this is an option I'm keeping open.
I found other options for motors. One was from the same place that had that bone yard motor that wouldn't spark which worked great and was on a pretty solid mower overall but had a questionable transaxle and missing deck. I can still get that one (and the no-spark thrown in).
However, over the weekend I found another one an hour away that was the right motor and claimed it just needed a starter motor gear. I got it, but the starter was clearly toast. I put in my old motor's starter and it struggles to turn over the engine unless the plugs are pulled. I assume my old starter was getting weak so I ordered a new one but wondering if there is some reason the motor would refuse to spin that might make me scrap the thing? I ordered the starter from Amazon and can return. Hoping for a little advise since I'm not sure why it wouldn't spin up.
/ Craftsman motor replacement? #16
It seems there are lots of tired starter motors on these OPTW. I've not used aftermarket motors, so I don't know how you will do. But I'd wait and see what that does and if it doesn't perform see what voltage you get at the starter as you try and crank it. I used to see getting them running for the first time after they would set for a couple of years, that they would do better cranking once you got them running.
I couldn't find an OEM on amazon so figured id try a 3rd party. I prefer mfg parts but sometimes aftermarket isnt terrible. The one on my blown motor looks ok externally but i havent opened it up. Im not sure if theres anything that can be done to recondition these anyway other than replacing brushes if they were worn out.
I swapped motor last weekend and it seems to be working great. The grass was really long and soaked so the mower bogged down several times. I cant imagine the old engine would have faired much better with it's extra 1/2hp. I think this one needs the carb cleaned so I'll probably swap the one from the old engine since i cleaned it last year.
This raises a question about the old engine. What parts should i hold onto? Was thinking carb and magneto to start. Maybe pull the flywheel and the alternator coil? Anything else worth having on the shelf before i scrap it?
/ Craftsman motor replacement? #19
I wouldn't save anything...except since I'm a hoarder I'd just save the whole thing.
Lol thats what I'm trying not to do. If something goes out on this motor I'd either fix it or move on. Trying to decide what i would actually fix and what used parts are worth installing on a second motor. Backup carb is obvious since it's clean/working and small. The magneto is small too but not sure they fail that often. Would i really change the alternator or flywheel? Probably not...
Actually, when i was test running yesterday it died on me as far as possible from the shop. Seems the carb was too rich/flooded so I'm going to swap the old/working carb over and eventually rebuild this one.
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
2003 International 4300 Flatbed Dump 571557 (A62613)
2003 International...
2 Row 3pt Bedder (A64119)
2 Row 3pt Bedder...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
Utility Cart (A59231)
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
