Quick Hitches Recommend me a quick hitch please
   / Recommend me a quick hitch please #1
buck boost
Paris, WI
Ford 4500 LB, M7040HD, B2920
Tractor: Kubota M7040
Primary implement: woods brush bull 720x (1200 lbs) woods says it's QH compatible.
Hi everyone. It's tough taking on and off the 6ft 1200 lb cutter. I don't have enough room in the barn to store both together inside, and I'm not gonna let my tractor sit out.
I would like to stay around $500 dollar mark if possible. I know that may not be possible. That mower is HEAVY. CAT 2 correct? Is a cheaper QH gonna be up to supporting a 1200 lb mower?
I also thought about getting a 7 or 8 ft flail mower, because that would fit in the shed attached. Then sell the woods. But flail mowers are not cheap, and I already have the woods. The woods does a great job cutting 5 ft tall grass, never tried a flail mower. So if I could get away with just getting a quick hitch, I'll go that route.
I put a harbor freight QH cat 1 on my Kubota B2920 to use on my 4ft cutter. I'm very happy with it, especially for the cost.
   / Recommend me a quick hitch please #2
I got a Pat's Quick Hitch for my tractor. You can buy it in Cat 1 or Cat 2. Mine is Cat 1. I appreciate it for its ability to take different width implements. With most quick hitches all implements must be close to the same width. There is a down side. I did have to extend the length of my mower PTO shaft - it was really too short without the quick hitch. I did get a longer top link, too. I may not have had to - that was my choice.
   / Recommend me a quick hitch please #4
I vote for the Euro hooks/Lower link hooks. You won't regret it. Easy to use, lasts a life time, trouble free and for how well it works, not that expensive (About $300 for the Cat 2 kit on AgristoreUSA).
It does require cutting the old links out and weld the new ones in but it's worth it. This applies to the tractors that don't come with it as standard.
   / Recommend me a quick hitch please #5
HF is running a closeout sale on that QH, fyi. I suspect it would handle your Woods as well... Of interest, your Kubota is Cat 1 and 2, depending on what attachment pins you use. Even my M9's are Cat 1-2. For the price, they are hard to beat and yes I suspect they are all Chinese no matter what brand you buy.
   / Recommend me a quick hitch please #6
Pats Quick hitch system is highly recommended, it is similar to the Euro system in many ways.
I suspected most were Chinese. I knew from the spec sheet that the 7040 was cat 1 & 2, but I didn't know if the QHs were the same.
I looked up the specs on HF QH and it says it's rated for 2000 lbs, so that works. It is only rated for up to 45hp, but I don't really think that is important.
I'll line up the QH on my B2920 to the brush bull and if it looks good I'll swap it over to the 7040.
The HF QH is $140, hella cheap if you ask me. I'll check it out over the weekend.
I won't be cutting off the telescoping link ends on my M7040. I do like the those look though.
   / Recommend me a quick hitch please #10
They telescope, just remove them. You can mail them to @MtnViewRanch and he will send them back ready to go.
My tractrs both have telescoping lower links as well and you cannot EASILY remove them. The boss that carries the telescoping end is securely welded to the end of the arm. Why I never pursued Euro Hooks or Pats is because the extendable lower ball mounts work just as well for me. If the weren't, I would have but because they are, I never considered it.
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
John Deere 50 (A60462)
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
2004 JOHN DEERE 650H LGP CRAWLER DOZER (A60429)
2004 JOHN DEERE...
