Blown & Repaired Head Gasket: Red Flag for Buyer?
   / Blown & Repaired Head Gasket: Red Flag for Buyer? #1
Suburban Plowboy
FL
Kubota L3710
Would you buy an 800-hour tractor that had a head gasket blow and was then repaired by a dealer?
   / Blown & Repaired Head Gasket: Red Flag for Buyer? #2
Yeah, IF it was priced correctly and the dealer gave adequate warranty assurance.
Head gaskets can blow for reasons other than abuse.
   / Blown & Repaired Head Gasket: Red Flag for Buyer? #3
If the price is to my liking i'd buy the vehicle.
I am looking at the tractor today. It's a TYM with a Kukje engine. The seller says the tractor's head was replaced under warranty "along with a list of other things." Sounds like the head was defective.
Plot twist: forgot to tell this guy I had corona. He is not interested in catching it. Now I have to wait a couple of days. He says the dealer put a new head on the tractor and a bunch of other junk on warranty. Says TYM fought them. His theory is that the dealer expected to take the tractor back, so they fixed it up for themselves.
   / Blown & Repaired Head Gasket: Red Flag for Buyer? #6
I was offered a Corona but I won't drink it. It's made by the same farts as Buttweiser. :poop: :ROFLMAO:
I'll tell you what. I'd drink a case of Corona before I'd touch one Budweiser. Especially Bud Light in the Loafers.
   / Blown & Repaired Head Gasket: Red Flag for Buyer? #8
I would want to see the paperwork from the dealer. People selling stuff have a habit of telling you what they want you to know, but not always everything you need to know.
The tractor has very low hours to need a new head gasket. I'm struggling to understand how that happened if it wasn't abused.
Here is what Grok thinks:
The most likely reason a low-hour diesel tractor's head gasket blew, assuming proper maintenance and operation, is overheating or thermal stress. Diesel engines, especially in tractors, operate under high compression and load, generating significant heat. If the cooling system fails to manage this heat—due to issues like a malfunctioning radiator, low coolant levels, a faulty thermostat, or a clogged cooling system—excessive temperatures can cause the head or block to warp, compromising the head gasket's seal and leading to failure.
Other potential causes include:
  • Improper installation during manufacturing or a prior repair, such as incorrect torque on head bolts or a defective gasket.
  • Detonation or pre-ignition from improper fuel quality or injection timing, increasing cylinder pressure beyond the gasket’s capacity.
  • Material or manufacturing defects in the gasket itself, though less common with reputable brands.
Since the repair included a new head, it suggests the original head may have warped or cracked due to overheating or excessive pressure, reinforcing overheating as the primary culprit. Checking the cooling system and fuel injection system for underlying issues would be critical to prevent recurrence.
Here is what ChatGPT thinks:
If a low-hour diesel tractor blows a head gasket and the repair includes installing a new cylinder head, that strongly suggests the original head was warped, cracked, or otherwise defective — and this was likely the root cause of the failure, not just a consequence.
Most likely cause: Factory defect or casting flaw in the original cylinder head
Given that:
  • The tractor has low hours (i.e., not much wear or thermal cycling yet),
  • The failure was severe enough to justify replacing the entire head, not just the gasket,
Then a manufacturing defect is the most probable cause. Here's why:
1. Warped or cracked head from the factory
  • A head that’s not machined perfectly flat or has casting flaws can allow combustion gases or coolant to breach the gasket seal even with low use.
  • A crack in the head can lead to overheating, coolant loss, or combustion pressure loss, all of which will destroy the gasket.
2. Improper torque at the factory
  • If the head bolts were not torqued correctly (too loose, uneven, or over-tightened), this can cause uneven clamping pressure, leading to premature gasket failure and possible warping of the head.
3. Cooling system issue from day one
  • A blocked passage or casting flaw in the head could cause localized overheating, damaging both the gasket and the head before many hours accumulated.
Less likely causes (but still possible if not a defect):​
  • Overheating from coolant loss or pump failure — though unusual on a low-hour machine unless there was already a flaw.
  • Incorrect fuel injection timing causing high cylinder pressures.
  • Operator error (e.g., lugging the engine excessively or running without coolant) — but again, rare for low hours unless abuse occurred.
Summary:​
Most likely reason the gasket blew: A defective cylinder head — such as a crack, warping, or poor surface finish — likely caused the gasket to fail, and that’s why the head was replaced rather than just resurfaced. This points to a factory defect, not wear or operator error.
If the tractor is still under warranty or recently purchased, this kind of issue should be documented and may be grounds for compensation or further inspection of the engine's build quality.
International S1900 (A56438)
International...
skeleton / rock bucket (A56857)
skeleton / rock...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
FORD 545D TRACTOR (A60430)
FORD 545D TRACTOR...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
