Painting a House Exterior
/ Painting a House Exterior #1
HawkinsHollow
SE TN
Branson 3015R
Well it is time to paint my house. I got a couple quotes came in about $4000-$4500 for our 1800 sqft single story house and the 650 sq ft garage. Seems kind of steep to me and I am out of money after our big addition and renovation, so I think I am going to do it myself. I have never painted a house before. I have caulked everything, I am fixing some minor window trim rot, scrape, then I am going to lightly pressure wash the whole house, and finally paint. I bought an airless sprayer from Harbor Fright and one of those big metal drywall knife things to block the paint spray. I have quite a bit of experience with spraying smaller items with an HVLP sprayer system, so I feel like those skills will cross over to house painting well. What am I missing? Tips, warning, advice is all appreciated.
/ Painting a House Exterior #2
Sounds like you've nailed the prep.
The one suggestion I have is "follow the sun". Try to always paint in the shade. Might take you 2-3 days instead of 1, but you'll feel better and the paint will cure better.
And don't skimp on the quality of the paint. You don't want to do this again in 2-3 years...
What material are you painting? You mentioned pressure washing. The advice I'm familiar with is to make certain all dampness is gone.
The addition is 7 month old primed Hardie, the original house is 70 year old asbestos siding (I am assuming it is original, house built in 1955).
I will be going with a nice Sherwin-WIlliams exterior paint. I DO NOT want to do this in 2 or 3 years and I will be saving money by doing it myself so why not splurge on paint?
The follow the sun tip is golden!! Thanks!
/ Painting a House Exterior #7
Watch a few YouTube videos!
And if you care about how the property looks afterwards:
Even with the paint shield, look close for what might need to be taped off so NO over spray gets on it.
The paint shield is magic in the hands of a pro. Amateurs can make it work on the big open easy areas, but it can get tricky in tight areas.
Take down window screens and protect doors and finished parts like door handles, outlets, outside spigots, electrical boxes, meter bases and meters, gas or electric conduit entrances, AC units using painters tape and masking paper.
You mentioned yours is single story, but be sure to use drop clothes over any roof areas you risk getting paint on roof shingles, also cover any sidewalks or landscape plantings you don't want spray to hit. You can move the clothes as you paint.
Two or three hours of prep work can save hours and hours of overspray clean-up.
Also pick low wind days and remove any vehicles you don't want spotted with wind drift.
I learned before YouTube was a thing by hustling ladders for a friend, a professional painter, doing a house to learn how he does it efficiently.
Since then I've painted (2) different two story houses on my own before selling, so it can be done successfully by non-pros...
Start on the back of the house to get your flow going, establish proper paint coverage and to tune the process, then move on to the parts everyone else will see...
Good luck!
/ Painting a House Exterior #9
Long long time ago a couple of us painted an asbestos shingled house. We used wide brushes and it was a slow process. That was before "civilians" had access to airless sprayers. It was even a few years after that till I saw painting contractors use them on projects. I recall having to spend some time doing the bottom edges of the shingles where they lapped out over the next one below. I've seen painters use thin poly taped over all the windows etc. to protect them.
Good luck!
LOTS of good tips, thanks!! Starting on back of the house to get dialed, brilliant!
/ Painting a House Exterior #11
Painted my house myself twice, took over a month both times, spent a few days pressure washing.
Last time about 4 years ago I hired a professional outfit, I was amazed at how easy everything looked, there pressure washer made mine look ridiculous ! After that experience I will never again attempt to paint my own house.
My house is 89 years old and still has the original cedar siding on most of it, did have to replace some of it when I replaced all the windows about 4 years ago.
/ Painting a House Exterior #12
I stain one side of my two story cedar sided house every year, with two coats of solid Cabot stain, always with a brush. It takes about 4 hours to setup the scaffolding, 8 hours of wire brushing and recaulking and 16 hours of brushing and another 2 - 3 hours for takedown. This is an August activity.
A friend has a similar sized house along with a two car detached garage both with cedar shingle siding. She just got a $30K quote to scrape, prime and apply two coats of paint. The painter needs to rent a man lift for two weeks. The painter is booked until late Aug, I'm guessing he really doesn't want the job...
/ Painting a House Exterior #13
I paint a few houses every year. I'll be starting a new one next week. I have three different sprayers, and they are great for certain tasks, but I rarely use them for painting houses.
Most of the work that I do when painting a house is prep work. That's usually about 3/4 of my time on the job.
Since you didn't say that you were painting anything made of wood, that will save a lot of time.
My favorite caulk is Big Stretch by Sashco. I think Sashco is the best brand out there and it's worth the time to go to Lowes to get it. I have a Home Depot close by, but they don't sell Sashco products, so I go to Lowes to get it.
Never pressure wash a house!!! There isn't anything worse that you can do to a house then force water into it where it was never built to keep water out. And once that water gets behind your siding, it will remain there for months. The TV Show, This Old House, had a great episode on this where they pressure washed a house, then came back six months later to tear off the siding and see what was going on. They found black mold under the siding, and they even found were it was still wet in areas!!!! Your house is engineered to withstand 60mph winds, not 2,000 psi of water pressure. The pressure washer will blow off caulking, force water into cracks and openings that you cannot see and even damage your siding.
If it's dirty, wash it with a hose and a scrub brush. Add some bleach or a house cleaning product if it's really bad. Most of the time, I sand off the dirty areas in my prep work.
It's almost impossible to get total coverage on Hardie with a sprayer. You have to spray it multiple times, or finish with a brush. I've found that it's faster to just paint it with a brush. The area that the sprayer misses the most is the under edge of the lap siding. But you'll find that after spraying, and going back to look at the Hardie, you'll see all sorts of spots that looked like they were painted when you sprayed, but there's no paint there when it dries. Hardie has so much texture to it that the sprayer just sort of blows the paint over those low areas.
If you are working higher than 8 feet and you need an extension ladder, be sure to have a stabalizer on your ladder. It makes it night and day easier to paint, or work on anything. I also have attachments on my ladder to hold the paint can, so my arms are free to paint and hold onto the ladder.
If you are just on a step ladder, and not painting up very high, be sure to have the bucket that can hold a can of paint on the ladder. I have two of these that I keep on different ladders.
For brushes, I prefer a soft bristle angle brush. They allow me to put more paint on the wall and get thicker coverage. When I'm done for the day, I wrap the brush in a plastic sack real tight to keep air out and use it again the next day. I can go all month without washing the same brush. On some jobs, I'll be painting a couple different colors, so I use different colored sacks for each brush. Home Depot for brown for one, Lowes grey for another and Sherwin Williams white for another. It's nice that each store uses a different colored sack when buying stuff from them!!!
/ Painting a House Exterior #14
Yep, NO PRESSURE WASH. I'm needing to paint my 2 story farmhouse and have been planning also. Good paint is a must. I am going to use a power roller like this
to be sure and get the paint worked in. I used it to paint my shop walls, from a 5 gallon bucket. Works awesome. I have an extension handle, but will rent a man-lift to get to upper story. A sprayer will not get the paint worked in at all...
  • Good Post
Reactions: JJT
/ Painting a House Exterior #16
I have painted my houses and rentals myself for 40 years or so. My best advice is
Get the best paint you can afford, that probably won’t be available at the big box sores
Prep work is vitally important to a quality finished look, priming bare wood and caulking are essential
Easy on the power washing, or you will cause moisture problems
Get the stabilizer kit for your ladder, it’s a huge help if you are painting windows, and of course, ladder security
Pull off all masking, as soon as second coat is applied, for best looking end result
If you are painting windows your gutters, avoid overspray on the roof, it stays there forever
/ Painting a House Exterior #17
I hired a professional painter to paint my house and I volunteered to help him. He used a sprayer in a way, that no other painter in the area would.
He put a heavy coat of paint on the bottom edge of the lap siding, aiming the gun at about a 45° angle to completely fill in any gap. Then, with a 4" brush, he spread the excess around a bit.
He knew I was doing it correctly when I started complaining about how heavy the brush was getting with all the paint on/in it.
Basically, the only job of the sprayer was to eliminate the motion of dipping the brush into a can of paint. It was a real time saver.
/ Painting a House Exterior #18
I painted my rent houses for years. One of my best investments was a gun with an adejustable width. When you get to the areas where you need a shield, make it narrow
/ Painting a House Exterior #19
No matter how hard you try, you're going to get overspray using that large drywall knife. At least tape some plastic over the windows. And park your car over by the K-mart! :ROFLMAO:
I did our 24x20 metal sided garage about 6 years ago with an older Wagner power painter. It was dark brown and we wanted it to match the light color of the house. I was very surprised by how well it worked and how fast it was. It took maybe 15 minutes to do a side. The cleanup of the sprayer took longer than the actual painting time.
Good luck with your project.
/ Painting a House Exterior #20
I also have a Graco paint sprayer. I was not impressed. Leaves a lot of leftover paint in the bucket and hose. Cleanup is a pain. Spraying a smooth/metal surface would be okay, but with a rough wood/cement/asbestos siding, I really like the Power Roller and maybe a brush to mash the paint into the seams.
Volvo EC210CL Excavator (A64047)
Volvo EC210CL...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
(INOP) 2018 JOHN DEERE 50G EXCAVATOR (A62129)
(INOP) 2018 JOHN...
BUNDLE OF 4"X RANDOM LENGTHS RED OAK FLOORING (A62131)
BUNDLE OF 4"X...
