Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #25,281
Our western hemlock is purdy high in the moisture content compared to other species
This Eastern stuff will squirt you when you drive a nail into it, even after a month off the mill. But those nails sure do hold tight.
   / Tractors and wood! Show your pics #25,283
Anyone have feedback on the Mech Maxx stump grinder?
Thanks
There is a whole thread on it in the attachments section:
Beware of the scam website that looks just like their real one.
mechmaxusa is the scam site currently listing it at $990
mechmaxx.com is the real site (currently on sale for $1399, or a hydraulic swinging grinder for $2899).
   / Tractors and wood! Show your pics #25,284
Hope you do. I love to get your feedback on it. I though the same about an Alaskan mill and have even made some short free hand planks but never quite got to making or buying one.
gg
I have had one for 35 years or so. Don't use it much anymore. I built a rustic log cabin and used it to make carrying beams and planks and stuff. Also flattened two sides of the logs. Re-built the ramp to my barn with Tamarac beams and planks. Good for odd jobs if you have the wood and time.
I used two types of ripping chains. The Grandburg has two sets of teeth. One is narrow [half width], filed different than the others, and set to cut deeper than the others.These sets are alternated along the chain. A real pain to maintain and sharpen.
The other type was a regular chain with a coarser angle. I never really saw any difference in the two.
The first slice off the log is critical as you need a straight edge , like a good plank, to run the first cut. If the log isn't straight and even there will be sags in the plank which need to be shimmed. Short cuts with short planks are easier. Once this first cut is done you are on your way.
I think it is good for specialty jobs and bigger wood like beams. Making boards not so much.
Requires a bigger saw. Lots of hot burn up time here!!
Logs must not be dirty.
Saw must be sharp.
Air filter plugs faster.
Log should be positioned off the ground like on saw horses or something as you need space underneath for the mill to run. And trying to saw all day pushing that mill crawling on your knees gets really old fast!
I have a guy handy now with a small mill so don't use it anymore.
   / Tractors and wood! Show your pics #25,285
Saw must be sharp.
Thanks Hoobie - that's just the kind of info I was looking for. I would only use it for small rough projects. Things I do now by snapping a line and going totally free hand.
gg
   / Tractors and wood! Show your pics #25,286
100 feet of hemlock doesn't look like much when the limbs are chipped.View attachment 3539806
Sort of like a wet cat.
More pieces, more work. Three ten footers worth sawing. A bunch of shorts to split for "camp wood" ;-)
119 rings by my count. Some really skimpy growth about 90 years back. I wonder what that was all about?
There is more than 100 sq. ft of sound bark peeled off the three bolts. To bad I don't have a dog house that needs to be shingled.
   / Tractors and wood! Show your pics #25,287
I only had time to cut one 1/2 face cord carryall load of dead ash over at my parents Saturday. Two of them had fallen across their yard, from the neighbors. I gave them a couple weeks to do something about it, but I’ve got sick of mowing around them so they had to go.
Now, I’ve got about 2 face cords stacked up in my splitter shed, waiting on the next rainy day, for me to split. Or maybe I’ll do it on a hot muggy day, so I can see how the new ceiling fan that I put in there works.
I got a nice cant hook in a “bundle” deal at a garage sale last weekend. That did a good job of rolling those ash logs. I’m glad I had two saws with me because I got the smaller one pinched on the first log. The only reason I brought the bigger one along was because I messed up the angle on my last file sharpen job, and I wanted to see how it worked. It didnt work too good but good enough to get the little one out.
   / Tractors and wood! Show your pics #25,288
I nearly always bring a heavy hammer and a wedge when sawing logs on the ground. Seems like the blade always gets bound up sometime. I suppose I push the cut a bit ;-)
Driving a wedge into the kerf takes 30 seconds, and the saw pulls right out !
   / Tractors and wood! Show your pics #25,289
I carry an axe in a holster on my tool belt for pounding wedges. The longer handle allows for easier pounding than a shorter, heavier hammer. Axe head sits in the holster on the back of the belt, with the handle pointing up. (I can't stand the handle dangling down by my legs.)
You can actually use the wedge to lift the log up off the ground: Cut down in to the log, once you have room, insert the wedge to hold the kerf open and prevent binding. Once you have cut most of the way through, pound the wedge in. As the kerf widens, it will bend the log, lifting the area you are cutting up off the ground, keeping your chain out of the dirt as you finish the cut. Handy when you can't just roll the log.
   / Tractors and wood! Show your pics #25,290
The row of split wood in the back ground was left over from last year that would not fit in the shed. I have moved that into the shed.
The pile of blocks/rounds cut from logs I pulled out last February are now split and air drying. They should fill the rest of the shed.
If I need to top off the shed I still have a half cord on my trailer.
gg
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
vergenes (A50657)
vergenes (A50657)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2019 CATERPILLAR 930M WHEEL LOADER (A51242)
2019 CATERPILLAR...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
