CK30 Oil pressure regulator
/ CK30 Oil pressure regulator #1
yammerjammer
Yanmar 2210
Can anyone help me locate the oil pressure regulator spring and ball? The service manual I have is not clear exactly where it is located, but says to service it. One parts diagram appears like it is behind filter housing but want to verify before I remove it. I have searched the net and cant find anything.
/ CK30 Oil pressure regulator #2
Your engine is similar to my daedong 4a200 in my mahindra. Did you find anything? I am going to take the filter housing off in the next couple days to try to find mine. I have started a separate thread for mine
/ CK30 Oil pressure regulator #3
I wouldn't touch it. No need to service it, you're just asking for problems, just regularly change your oil and filter, and you will be all set.
/ CK30 Oil pressure regulator #4
Its probably just behind the oil filter under a cover held on with a single bolt. You will likely need to pull the whole gearcase cover to check/change it.
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
2017 BX2680 Sub Compact Utility Tractor (A61307)
2017 BX2680 Sub...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2015 Peterbilt 567...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
2022 SANY SY35U EXCAVATOR (A59823)
2022 SANY SY35U...
