SA424 Air filter housing rubbing
/ SA424 Air filter housing rubbing #1
MACflyer
West Virginia
Yanmar SA424
My 424 is 4 years old with 600 hours on it. I recently noticed the air filter housing assembly is just loose enough that it has worn a fairly large gash in the top of the radiator. I’m surprised that the plastic housing is the winner in a plastic rubbing on metal situation. I stuffed a bit of rag under the backside of the housing to create a makeshift shim for the day, but I’ll need to devise a more permanent solution when I get back from work. Has anyone else encountered this issue?
/ SA424 Air filter housing rubbing #2
Would you be able to post some pictures of your set-up. I have a SA425 and believe the filter set-up is similar to that in a SA424. Pictures may help point out issues readily and make it easy for folks to provide feedback.
I'm not home so I didn't think about a picture. Enlisted my wife to get one, you can see it's worn most below the circular part of the air cleaner where it has a sharp edge. There's additional wear below that, where the bulk of the filter housing sits although it's not as severe.
/ SA424 Air filter housing rubbing #4
I will post some pictures of my set-up later today. I do inspect the air filter periodically and have not noted any atypical issues with securement of the assembly. More later.
/ SA424 Air filter housing rubbing #5
After I finished mowing today, I took some pictures of the air filter setup on my SA425. It looks similar to your setup and I am sure eventually it will start gouging a crease into the radiator top. There is minimal gap (~1 mm) between the housing and radiator. What I am going to do is get a thin enough flat foam strip and stick it to the radiator top. This will act as a barrier and cushion, and hopefully I can avoid damage. You may wish to look into something similar.
Thanks for pointing this out. It helps owners in general. I have attached a couple of pictures.
Hays LT1 Tender (A61307)
Hays LT1 Tender...
213090 (A64276)
213090 (A64276)
ROAD GEAR ALUMINUM HEADACHE RACK (A64277)
ROAD GEAR ALUMINUM...
2006 International 4400 Horton Emergency Truck (A64556)
2006 International...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
