Pictures from an athletic field contractor
   / Pictures from an athletic field contractor #271
Do you use a finish flail mower with dethatching knives?
I have a Thatchmaster Verticutter that I use on some fields.
   / Pictures from an athletic field contractor #274
Maybe a bit of an aside, but got any recommendation on a walk-behind slit seeder, @Complete Turf Care ? I'd been thinking about getting one of the 3-point, but after seeing prices mostly near or above $10k, I decided I don't love my lawn quite that much. I had imagined spending closer to $3k.
   / Pictures from an athletic field contractor #275
There is no need to cut holes for the sprinklers in this case, because the sod is being shredded as it goes through the sprigging machine.
When we are laying solid sod and not sprigging it, yes, we cut holes for the sprinklers to pop up.
In this case, we used 43 rolls of sod to sprig this field. Last time we installed solid sod, we used about 400 rolls of sod.
The difference is about $50,000, but the solid sod field would be ready for use in about 15-30 days, whereas the sprigging takes about 70-90 days.
I go over the savings with my customers often. Seems a lot of people want an instant lawn or field. Where it is left to me I much prefer seeding grass areas and planting very small trees. I think it increases the chance for more uniform root structures leading to less weeds too.
Athletic fields are expensive real estate with someone always making plans to rough up your hard work. I am glad to stop in on your thread and see you still working your plan and business. Your expertise and commitment are obviously on the rise and I hope you can keep at it for many more years.
I am still laser leveling fields and enjoying retirement.
Sometimes we make the decision to work, or not to work, on a holiday based on the weather forecast. Today, I applied fertilizer and herbicide on a baseball field.
Sorry, but I don't know of any walk behind models. That's not something that I would use.
   / Pictures from an athletic field contractor #279
I hate lawn thatch, have you considered using a flail mower equipped
thatching knives with a pick up basket that uses a hydraulic basket lift
to dump it to do this job in one pass?
I went check on the field we sprigged almost 2 weeks ago. I'm pleased with the progress. I'll give it about 2 more weeks to get more roots down, then I'll start pushing it hard with fertilizer.
Westfield Conveyor (A56436)
Westfield Conveyor...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
