Buying a ZTR, what should I look for, or avoid?
/ Buying a ZTR, what should I look for, or avoid? #21
The wife wants a ZTR and with the number of trees to go around it's a chore trying to do it with the tractor which only has a brush-hog. 5 acres is probably the maximum that the ZTR would see and the hills are gentle.
The local dealers carry Cub Cadet, John Deere, Stihl and Gravely. The big box stores are Lowes and Tractor Supply.
Personally I'd prefer to avoid the big box stores as they don't service what they sell and some things tend to get discontinued quickly.
I have no experience with ZTR's and almost all my small engine stuff has been powered by Honda engines so I'm not familiar with the Kohler, Briggs, etc. in their current incarnations (go back 50 years and I'd swear by Briggs). My UTV is powered by an 812cc Kawasaki and I've had no issues with it.
So... What should I be looking for?
avoid low end units, look for residential/commercial quality.
I compared engine, which transmission vs price
/ Buying a ZTR, what should I look for, or avoid? #22
I bought a used diesel Kubota ZD26 with a bagger two years ago. Extremely pleased. New diesels are very expensive and complex with emissions.
/ Buying a ZTR, what should I look for, or avoid? #23
I'd buy a commercial unit. I have a Hustler X-One 72"... It's been a beast. About 1300lbs. Parker pumps.
/ Buying a ZTR, what should I look for, or avoid? #24
Spend the most you are comfortable with for a good quality built machine and if bumpy in the cutting areas suspension is better but suspension seat is good too. It all adds up quickly and a good quality machine can be over 10g's.
/ Buying a ZTR, what should I look for, or avoid? #25
I have never seen a hydro rated for acreage. However the hydros are rated for a max weight. Many companies will skimp on they hydro creating a mower that is to large for the hydro.
Toro Titan 60", 845 lbs.
I've not actually seen that rating either, but heard mention of it on a few video's when researching.
I have seen recommended lawn size on mower manufacturer sites.
I'm guessing homeowners average around 50 hours a year on their mowers, commercial guys probably average 10 times that. So in my simple mind, if I buy a mower designed to run 500 hours a year, and only run it 75 hours a year, it's going to last me a long time. And if I run a homeowner model 75 hours a year it won't last long.
/ Buying a ZTR, what should I look for, or avoid? #26
It looks like you have Country Clipper dealers down there. We've had one for several years and have had no problems. I like the one hand joystick steering along with the flip up deck for under deck access.
/ Buying a ZTR, what should I look for, or avoid? #27
Not true. The Kubota 1211 has no emissions equipment. It is expensive though.
/ Buying a ZTR, what should I look for, or avoid? #28
not bad, you'll have to scroll through the intro though
/ Buying a ZTR, what should I look for, or avoid? #29
It really is fun mowing with the new Husqvarna z-454 that I bought for my parents place this spring. We are on vacation up in the mountains with the in-laws this weekend but I can’t wait to stop and cut my parents lawn on our drive home Monday.
It would be tougher waiting, were the smallmouth bass not biting up here like they were going out of style. I had to let all them go (season don’t open till June 15). I only caught one “target” perch so far.
/ Buying a ZTR, what should I look for, or avoid? #30
Both our mowers are listed on that video.
We have a 2013 Hustler Super Z (35 HP Kawasaki with 72" deck) and a 2020 Snapper Pro s200xt (37 HP Vanguard EFI with oil guard and 72" deck)
/ Buying a ZTR, what should I look for, or avoid? #31
Uses HydroGear 2800 that is rated at 1000 lbs max.
That leaves 155 lbs for the operator and 5 gallons of gas (30 lbs) so dont fill it up and weigh more than 125lbs.
I was a Husqvarna dealer for 12 years, just changed careers a year ago. Trans axles are used in lawn tractors. ZTRs use 2 pump/motor units, at around 1000# a piece, giving you nearly 2000#.
As for the OP, If you went for a Husky, I would say a minimum of a Z4xx series, it is a robust residential unit. If I were doing what you are, I would buy a Walker, hands down.
/ Buying a ZTR, what should I look for, or avoid? #32
sounds like you done right. as a footnote that seems obvious but will say anyway: within a manufacturer, there are both consumer (box store quality) all the way up to heavy duty commercial grade models.,
mention this as a friend has a lower end Hustler (raptor i believe) that has been one headache after another incl replacing pumps. highly suggest going upper tier on any manufacturer.
many of the upper end models use Parker pumps, & Hydro Gear motors
/ Buying a ZTR, what should I look for, or avoid? #34
extensive info above, good points. another component oft overlooked is rear wheel/tire size. many lower end models have barbie sized rear wheels. just as in tractors, get the largest wheel size avail for a better ride & traction.
/ Buying a ZTR, what should I look for, or avoid? #35
The other thing to keep in mind, is what grass you are mowing. Some decks do good with one kind of grass and terrible on other grasses. A good idea was mentioned earlier... what are the local pro's running? They won't run machines that don't work well with your local grasses.
/ Buying a ZTR, what should I look for, or avoid? #36
25 or 26 HP is the maximum cut off before T4 emissions are required. At work we had a ZD331 pre-emission and I liked it so much we ordered a new one in 2018. The newer one had T4 emissions; a small turbo looking device, a large filter but no DEF. Kubota tacked on additional of frame in the middle to accommodate the additional length which allowed enough flex to make opening the hood difficult at times. It would do a burn off occasionally and the purchase price reflected the additional plumbing and electronics. The pre-emission ZD331 was by far better than the T4 zero turn in ride, quality of cut, purchase price, and reliability. Maybe they're better now.
/ Buying a ZTR, what should I look for, or avoid? #37
Yea, it's 25. I think the 1211 is 24.6 or something.
/ Buying a ZTR, what should I look for, or avoid? #39
I've never seen a ZTR with just one of those transmissions. Must be a unicycle ZTR. :ROFLMAO:
/ Buying a ZTR, what should I look for, or avoid? #40
But, since Winter Deere is really down on B&S engines, Intek particularly...
The Intek engines might be as reliable as concrete, maybe I should haven't sounded so harsh. I was just arguing I would personally stick with the nearly-ubiquitous Kawi V-twin. They're so common that everyone knows them, parts are everywhere, and YouTube is chock-full of videos on how to deal with every problem you'll ever have with one. Replacements are also easily available, when faced with the worst-case scenario.
But I actually own three pieces of equipment with Briggs engines, and one is an Intek. I don't love them, the head bolts are forever working themselves loose on one, and the Intek has more engine noise coming off the intake than probably any other engine I've ever owned. But they do work, and I have to admit they've all been reliable.
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
2017 International HX620 Quint Dump (A62613)
2017 International...
2004 STRICK 53X102 T/A DRY VAN TRAILER (A59914)
2004 STRICK 53X102...
2018 Chevrolet Impala Sedan (A64557)
2018 Chevrolet...
(6) 4ftx12ft platform grating  (A62679)
(6) 4ftx12ft...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
