TYM 233 rear axle seal replacement
   / TYM 233 rear axle seal replacement #1
sarakodi
I have a TYM 233 approximately 15 years old
Both rear axle seals are leaking and I thought I would replace them myself along with the barring's. I attempted to remove one side and cant seem to pop it out.
Has anyone ever attempted this on a TYM tractor if it's in fact the same instructions?
Thanks in advance
   / TYM 233 rear axle seal replacement #2
You'll need to remove the entire axle housing #1. It might be tricky because there are a couple of close fit alignment pins, along with RTV that tends to glue things together.
Keep in mind all the brake parts. I don't know if those stay in the tractor or come with the housing.
Then, should be a matter of taking the snap ring #15 out and slide the shaft out, so you can finally get to the seal.
Thanks in advance
Thank you ptsg
Looks like this machine is going to get loaded onto trailer and taken to someone who works on them.
JD 772-A Grader (A47371)
JD 772-A Grader...
2013 John Deere 350G LC Hydraulic Excavator (A46683)
2013 John Deere...
2025 Future Stump Grinder Mini Skid Steer Attachment (A46683)
2025 Future Stump...
2018 Quality T/A Car Hauler Trailer (A46683)
2018 Quality T/A...
2016 John Deere 318G Skid Steer Loader (A48837)
2016 John Deere...
2013 JLG 600S TELESCOPIC BOOM LIFT (A48992)
2013 JLG 600S...
