Struggling with MX5400 purchase — could get MX6000 for same price. What would you do?
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #41
How about draft control? I’ve never had it but on my current tractor I’d often have the single bottom plow dig real deep and stall the tractor at points
That's a good point. I like draft control, but then I grew up with tractors that had it.
If you plan to use ground-engaging implements like a plow or disks or anything with deep tines, then draft control is very nice to have. Having it is never a disadvantage, and on rough land - land with a lot of stones or roots or buried trash - then draft control is nearly a necessity.
Draft control is common to Ag tractors, and probably more often found on tractors ordered with manual transmissions and destined to do annual plowing.
The mechanical parts that regulate the draft control are internal to the hydraulics of the 3pt.
So although it is listed as an option, I wouldn't be surprised to find it is a factory option rather than dealer option. Ask your dealer.... I've never heard of it being added to a tractor later.
BTW, you asked for opinions. So if I were buying, I'd want to get at least one set of remotes for the rear hydraulics. Having one set sure is handy, and makes it easy to add more later if wanted.
And I'd go with whichever dealer I enjoyed doing business with. All those prices are too close to being the same to influence my choice of dealer.
good luck,
rScotty
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #42
The CID grapple is a ~$3k piece, weighs 200# more (eating into the carrying capacity and wear on the front axle / need for counterweight), is probably mild steel; versus the LP grapple which is ~$4.5k and made from AR400 steel. The LP is much nicer. Consider the LP unit to be at least a $1.5k price difference - I'd personally consider it worth more than that in the price difference because of the noted differences (earlier this year I made a similar choice in grapples between mild steel & heavy & cheap vs good steel & light & a bit more $; guess what I chose).
Is the local dealer also adding the 3rd function? If not, that's an added expense as well.
Do you anticipate actually having a "relationship" with the dealer?
I've had a long term barely-there relationship with my tractor's dealer who's 100mi away - I bought it 8 years ago, shook hands, they delivered it a few days later, we shook hands again. I've bought sundry parts from them via phone call -> mail delivery as well, nothing to fix problems with the tractor (except a radiator which was very much my fault). If I'd bought local for a "relationship", I would've paid a ton more for much less tractor, which also may or may not have needed a "relationship".
I have a CID grapple. Its AR400. Better than the LP and less expensive. I'd have to compare the models, but when I was shopping, it was lighter than the LP. 100% the best piece of equipment I have.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #43
good luck,
rScotty
rScotty is right about the hydraulic remotes. Get as many as you can afford! I got two remotes and I wished I had gotten three. When I hookup my hydraulic side shift flail mower, I have to take off the hydraulic top arm because the flail takes two remotes. It sure would be easier to have that hydraulic top arm when hooking up and adjusting the trim of the mower than adjusting the manual top arm.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #44
Yep, get three remotes when you purchase the machine. It costs a lot more to add them later. And the more, the better.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #45
The only reason it would cost more is if the customer’s tractor has to be picked up to add a third.
Otherwise the labor charge is exactly the same.
I would agree that two remotes are better than one but figure out first if you’re gonna need a third.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #46
Agree wholeheartedly.
2 remotes is not enough. I encourage 3 or 4 sets.
You won’t regret this small expense on this large of a purchase.
My MT655E has 6 sets and with the electronic style remotes being prone to spool failure, it’s good to have a few extra sets of remotes. #6 is “out” on mine right now. $1,000 for a new solenoid. I can live with 5 sets lol
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #47
IDK but it sure cost more when I had mine installed last year. Probably because it’s easier to add remotes to a crated tractor before installing rear wheels than doing it afterwards when the machine is fully assembled, and I suspect some of the difference is simply what corporate prices establish on the machine builder versus what dealers can get away with charging for service.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #48
3 is mandatory for me :unsure:
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #49
Did you know the difference in price?
Also, from when you purchased the tractor, to when you retro installed, what was the time frame?
I have seen these things go up $200 within a year.
Also, removing a tire is no big deal and would only add about $25 worth of labor. Having a gantry at the shop makes a loaded tire removal rather simple.
I don’t know what other dealers do but we as a dealer do not “ get away with” anything except a satisfied customer.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #50
The price builder shows what it costs to order new. Comparing the new tractor price builder to what 4 different dealers quoted (and I paid one of them) was about 40% more than ordering at the time of purchase. Non- warranty and new sales service work must be where the profit margins are for dealers. IDK if your dealership has a different business model, but this was my experience.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #51
So you’re talking installations from the factory or assembly point?
Remotes that are standard on our products are not listed as separate pricing items.
You can rest assured that they have built in pricing
however.
If a customer wanted more, I haven’t seen the option to order more on our builder site.
The option must be at the dealer level to my way of thinking.
Hence the same pricing if always provided by the dealer.
We hardly sell our largest 6000 series. But even on that build site, I still don’t see an option listed for more remotes there.
That tractor comes with one or two remotes but states the option for more.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #52
however.
The top and tilt kit (2 remotes) ordered with the tractor is $1098. When I had 3 remotes installed post purchase from the dealer, I paid $3500. And this was the cheapest quote of 4 different dealers.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #53
I bought my tractor intentionally without rear remotes with the plan of doing it myself. Cost me about $400 to add them where the dealer wanted 4 times that to add them before delivery.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #54
I thought about doing that, but the factory kit levers fit so nice in the designed slots and feel ergonomically correct. The aftermarket kits just look and feel like clunky add ons to me. This likely doesn’t matter to most people.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #55
I didn't use a kit, I purchased a two spool valve from summit and plumbed it in. I mounted the valve on the right side fender where it's just inches away from the tip of the loader valve so operating it is so easy and feels very natural. I honestly can't see it being any better or easier. Had I opted for the factory kit, the levers would have been down and to the side of the seat which I wouldn't have liked.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #56
For those quoted prices I hope this MX comes with a cab.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #57
  • Local dealer MX5400 — $49,250 (who I'm currently working with)
  • Other local dealer MX5400 — $47,000
  • Other local dealer MX6000 — $49,000
  • Dealer 3 hours away MX6000 — $48,600 delivered
I priced 5 area dealers when I bought my Kubota.
I'm jealous of you Kubota guys!
Around here, all the John Deere dealers consolidated into a mega group. There is no shopping around any more if you're green.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #58
Don’t feel too badly. With factory incentives and finance programs, pricing is not that much different from dealer to dealer of the same
brand.
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #59
brand.
That’s very true. About the only significant variability is what dealers will do to close the sale, like tire filling, free delivery, ect…
/ Struggling with MX5400 purchase — could get MX6000 for same price. What would you do? #60
Hay Dude what is the part number on your solenoi
I'll see what I can come up with
willy
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A61307)
2024 Kubota...
2010 Case 580N (A60462)
2010 Case 580N...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
2025 Pabreak 80in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2013 VOLVO SD115D PADFOOT ROLLER (A62129)
2013 VOLVO SD115D...
2014 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
