Land Pride Flail mower duckfoot blade replacement question
   / Land Pride Flail mower duckfoot blade replacement question
Do those knives/hammers come in matched pairs? Sure would save a lot of time vice weighing them all.
No,t hat's not really needed. With all new blades and mower should be balanced unless it's been damaged somehow. There are some rare mowers that have an unbalanced shaft that balances with the stock weight blades but not others. Most are balanced with any type of knife that fits. I've had shafts balanced before but unless something's way off it's a waste, IMHO. Hit a rock or 50 and it'll be out again. We've got lots of rocks so...
   / Land Pride Flail mower duckfoot blade replacement question #12
The side slicer knives are sheared, punched with the correct mounting hole, ground to a fine edge and then pressed to create the correct angle.
The scoop knives are created in the same manner with the knife forming done before the cutting edge is ground as far as before they are heat treated as far as I know.
The high quality heavy cast hammer knives have hanger holes that are drilled at a slow speed after the castings are cooled completely using a
cooling and cutting fluid as far as I know and the cutting edge is wet ground.
   / Land Pride Flail mower duckfoot blade replacement question #13
My Maschio manual says the hammers need to be replaced in weighed pairs. As fast as that drum spins it makes perfect sense to me.
   / Land Pride Flail mower duckfoot blade replacement question #14
I think it's saying not to put a worn one with a new one.
But if you are replacing with all new you should be good.
If you are putting used ones on you will need to weigh them into pairs.
   / Land Pride Flail mower duckfoot blade replacement question #15
My reading comprehension is not lacking. My flail has really heavy hammers on it. 1/2 oz here and 1/2 oz there placed it the wrong places and you have an out of balance rotor. You guys put your blades wherever you want. Hammers are a different matter altogether.
   / Land Pride Flail mower duckfoot blade replacement question #16
Hammers are awesome unless you want a lawn.
Longterm update on knives for those with this Land Pride mower. The P66945 scoop/duck bill blades work fine and are way cheaper from my local Deere dealer than what the factory blades list for. It's a pretty crazy difference at about five bucks a blade from my Deere dealer in packs of 10 and Land Pride lists them at $37 a piece. I still haven't tried to adapt it to the Y knives but they probably won't work very well because they aren't listed as an option from Land Pride.
2393 (A58376)
2393 (A58376)
IRanch High End Electric Tricycle (A57149)
IRanch High End...
2014 VOLVO A25G OFF ROAD DUMP TRUCK (A52709)
2014 VOLVO A25G...
Giyi 66" Rock Bucket (A57149)
Giyi 66" Rock...
LOT: (2) Gear & Pulley Puller Sets (A59076)
LOT: (2) Gear &...
4R RIPPER BEDDER (A52708)
4R RIPPER BEDDER...
