I'm having trouble starting my tractor. I had a friend of mine check it out. He removed all the relays and I'm not sure if he put them back in the correct positions. Can someone tell how the relays are positioned in the correct sockets?
Look inside the fuse box cover. My 6520 has them labeled there. What was the tractor not doing before he removed the relays? When mine won't start and nothing happens when I turn the key, it is a loose connection on the bottom of the gear shift lever.I'm having trouble starting my tractor. I had a friend of mine check it out. He removed all the relays and I'm not sure if he put them back in the correct positions. Can someone tell how the relays are positioned in the correct sockets?
