Tc55da 3pt lift issue
/ Tc55da 3pt lift issue #1
cnall12
Tc55da
I am currently working on getting a tc55da repaired and operating correctly. The tractor has an 18LA loader. The issue I've come up with now is that the 3pt lift will not raise. All other hydraulics work on the tractor including secondary remotes. I've pulled the speed control valve completely out and there is no oil flowing there. I'm at a loss of why a single part of the system just isn't working. Could someone give me some advice?
/ Tc55da 3pt lift issue #2
Oil isn't supposed to flow there. The valve only provides a metering restriction to control the down rate of lowering. You have rockshaft issues.
Any ideas on where to start or resources for digging into it?
/ Tc55da 3pt lift issue #4
More details about the problem might help. Did it work right at one time? Has anything been changed or worked on since it did work? Has the tractor been parked for some time unused?
It has sat up for a couple years. I'm looking into buying it but the owner believed the lift worked prior to being parked. I dont have a lot of information on it.
/ Tc55da 3pt lift issue #6
Then it's probably just got something stuck in0 a control valve somewhere. Nothing broken anywhere. Probably an easy fix for someone familiar with the system.
/ Tc55da 3pt lift issue #7
Just curious, how many hours and asking value ?
It has 1600 hours but the asking price is pretty low because the loader was abused by the owner prior to them. They bought it to repair but never got around to it.
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
2015 John Deere 3046R Compact Utility Tractor (A63116)
2015 John Deere...
2010 FORD F-150 XL CREW CAB TRUCK (A62130)
2010 FORD F-150 XL...
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
