This is a 4 foot bush hog modification that I did to adapt it to my 2425
   / This is a 4 foot bush hog modification that I did to adapt it to my 2425 #1
Tchamp
Baldwin Georgia
Power trac PT-2422
That pump that I have it turns the PTO at 400 RPMs, but the shaft is a one and a half to one so my blades are spinning at 600 RPMs it works better on it than it did on my yanmar tractor
It cuts underbrush really well ,briars and thickets. You just raise it up over the top of them set the blade deck at a 45 degree angle so it doesn’t kick debris back at you and just set it down and it just chews it right up.
If I remember correctly, I bought the pump at the surplus center, the yokes were bought at my local agricultural store. They were the ones made for my PTO on this particular brush hog.
   / This is a 4 foot bush hog modification that I did to adapt it to my 2425 #2
I dont know why PT doesn’t use normal gull wing blades bolted to a stump jumper like this. Looks like you angled the PT plate enough to point the deck away from the operator, too. How does your PT handle this setup without any wheels on the cutter like PT puts on theirs?
   / This is a 4 foot bush hog modification that I did to adapt it to my 2425 #3
Your photos give me some ideas for my bush hog. I would like to fix the quick attach plate at an angle like yours, so that I can come down on top of a brush pile like yours can. I have the PT bush hog. I already added the stump jumper and gull wing blades.
   / This is a 4 foot bush hog modification that I did to adapt it to my 2425 #4
WOW ! Nice.
I suggest you locate a 4 yoke equivalent CV joint instead of the 2 joint unit. This because ANY misalignment along the axis connecting the shafts will introduce a torque variation that will fail a bearing, shaft, or seal, or even the mounting plate. Your installation is begging for a tri-pod joint to be put there from a front-wheel drive car's outer driveshaft.
   / This is a 4 foot bush hog modification that I did to adapt it to my 2425 #5
View attachment 3419125View attachment 3419126View attachment 3419127View attachment 3419128
It cuts under her brush really well briars and tickets. You just raise it up over the top of them said the blade at a 45 degree angle so it doesn’t kick debris back at you and just set it down and it just chews it right up.View attachment 3419130
If I remember correctly, I bought that at the surplus center the yolks were bought at my local agricultural store. They were for my PTO on this particular brush hog.
Nice job!
   / This is a 4 foot bush hog modification that I did to adapt it to my 2425 #6
Your photos give me some ideas for my bush hog. I would like to fix the quick attach plate at an angle like yours, so that I can come down on top of a brush pile like yours can. I have the PT bush hog. I already added the stump jumper and gull wing blades.View attachment 3421513
Did you drill out a standard stump jumper to bolt up to the PT center drive?
I’m going to put a set of wheels on the front and the back of it that like casters that swivel I haven’t gotten them yet, but I just float it on the big brush and stuff right now. I’m going through the woods cut and I just let it float about 3 inches above the ground and let it cut
   / This is a 4 foot bush hog modification that I did to adapt it to my 2425 #8
Yeah, I took it to a Machine Shop and they drilled out those holes to attach it. I’ve been using it now for a few years and it works out well.
   / This is a 4 foot bush hog modification that I did to adapt it to my 2425 #10
That was years ago now, and I remember I googled “stump jumpers”and came up with the size that I have. Next week I can measure the stump jumper and the blades for you. I do know where I got the bolts for it because I have that saved in a file.
2017 HINO 268 BOX TRUCK (A54607)
2017 HINO 268 BOX...
WHIRLPOOL WASHER & KENMORE ELITE DRYER (A54757)
WHIRLPOOL WASHER &...
CUSHMAN HAULER PRO ELECTRIC GOLF CART (A54756)
CUSHMAN HAULER PRO...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
2005 KOMASU D39PX-21 CRAWLER DOZER (A52705)
2005 KOMASU...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
