Got rid of the wheel bolts.
   / Got rid of the wheel bolts. #1
BravoXray
Elite Member
Nothern Indiana
Kubota BX2230, John Deere 430 Diesel
I haven't had to take wheels off my BX2230 very often, but when I did, I always cursed the damn wheel bolts. They are a real PIA to get back on, even after I made a couple of alignment studs. A while back, I replaced the front wheel bolts with 7/16"-20 studs and nuts, and the one time I have had one off since, it was a whole lot easier to remount.
So, I finally replaced the ones on the rear wheels today. I bought some 1/2"-20 threaded rod from McMaster-Carr, cut it into 2" long pieces and bought ten 1/2" wheel nuts at NAPA. I removed three of the bolts on each wheel and installed the studs with blue Lock-Tite. I let it set up, installed the nuts and then replaced the other two bolts. Torqued them to 70 ft lbs, so it's all ready to go for mowing season.
   / Got rid of the wheel bolts. #2
I hope you got Grade 5 threaded rod, at least...
   / Got rid of the wheel bolts. #3
Just curios what stops them from backing out, the Loctite? May not happen, but seems it could back out. I know 70# torque is pretty stout and that may be all thats needed. Just a new way of thinking to me, then again I don't have a Kubota either, so hard to fathom your complaints with mounting them.
   / Got rid of the wheel bolts. #4
Yes, it's grade 5. Grade 8 would have been overkill and three time the cost.
I have no idea how they could back out, between the Lock-Tite and the thousands of pounds of clamping force provided, I see no more possibility of them backing out than that of the original bolts backing out. Ain't gonna happen.
My thoughts exactly. I'd have searched out "real" wheel studs, like these - if there's room to get 'em in from the back.
To install auto style studs, I would have to had to remove the tires, which are loaded with fluid and heavy, remove the axles, drill out the axle flange to a specific size for the studs, and the press them in. Now, if any subsequent owner wants to put the bolts back in, which are in a bag with all my other spare Kubota parts, just remove the studs and install the bolts. Way simpler and cheaper. I only have about $30 in the threaded rod and nuts.
   / Got rid of the wheel bolts. #6
The only thing that I have noticed with studs is the exposed threads fill with mud or crud making them more challenging to remove the nut but still far superior in lining up the tire for mounting.
A little surprised American SAE threads on a Kubota.
   / Got rid of the wheel bolts. #7
Put but bolt marker pen on all my lug nuts and subframe bolts so I can visually check without having to get a torque wrench etc out.
   / Got rid of the wheel bolts. #9
I actually agree with you on studs vs bolts for wheels. Since I now own a couple German cars, I have gotten to find that they like bolts vs studs on every american and Japanese car and truck I have previously owned. Bolts are much more of a PITA. On my Grand L-series Kubota, the wheels have 2 studs and the rest bolts. Clearly the reason for that is usability as it is a royal PITA to line up and start a wheel with only bolts. I can only conclude that bolts are cheaper.
I just wanted to make sure you used decent material as when someone says threaded rod, most of what you find is low grade stuff. As you know, you can find higher grade material from places like McMaster, but you need to know to do it. Sounds like you should be covered (y)
Hummmmm...Why blue? I would have used red LOCTITE myself. Just curious...
Because that's what I had in my toolbox. Didn't feel like spending another $20 on a bottle of red that I would probably never use again.
I mowed three acres with it today, neither of the wheels fell off, and after I finished up, I rechecked the nuts, the torque was still right at 70 ft lbs.
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
2018 JOHN DEERE 333G SKID STEER (A51242)
2018 JOHN DEERE...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
