spruce Deere
- Joined
- Feb 1, 2009
- Messages
- 1,224
- Location
- Northmost Idaho
- Tractor
- John Deere 790 with loader, LS xr3140h loader and cab,1150 case dozer
As in all businesses, there is ups and downs. Farming is no different, well maybe worse...
Had a record rash of things busting and or suddenly not wanting to work this spring.
First was the 790. I was tilling with the 790 one field with a long gentle slope on one end. Been using the 4wd to help keep the tractor straight on the slope then just as I only had a few passes left, I had no front assist to help pull me straight, lost power to the front tires. Finished out tilling and marking rows with a 2wd 790. After there was time to look at the 790, turns out the bolt that fastens the yoke to the diff shaft had worked its way out and let the yoke slide off the splinned shaft.
Next I was cultivating in a different field with my danish tine cultivator and the LS. I was again just about done and then a loud SNAP.... one tine broke off and was hung up in the rest of the tines. 'Power for the course' I said out loud. Finished cultivating minus one tine.
Next, i was sub-soiling with the LS to break up a field small field that had not been worked in 5 or 6 years. Right at the half way point of being finished a 'feel' it threw the tractor, resounding heavy 'clunck' sounded. I instantly stop and see the one inch thick hitch beam lof the sub-soiler completely broke in two from the sub-soiler.
Out of all of this malarkey, the LS just was plain reliable threw it all. Did not get a pic of the busted danish tine, was not in the mood... blue line in sub-soiler pic is blotting out 'desciptive' words
