BravoXray
Elite Member
- Joined
- Dec 17, 2019
- Messages
- 3,414
- Location
- Nothern Indiana
- Tractor
- Kubota BX2230, John Deere 430 Diesel
I was just getting ready to make a post.
Short answer, no I didn't find what or where the leaking voltage is coming from. I spent a few days with the dash out tracing wires on everything I could imagine was the culprit, but couldn't find it. I even set the cluster up and resting on the steering column, hooked up all the connections that go to it, and it didn't malfunction. I even ran a ground directly to the body, even though there are two other wires that provide hard grounds from the cluster to the body.
Then I finally went ahead in screwed it in place and the problem was back. Unfortunately, there is no room to get behind the cluster and disconnect the harnesses one at a time to try to isolate it. The only possible clue, even if it is related, is that the brake light comes on dimly when the key is in the accessory position, whether the parking brake is set or not. But, pulling the brake fuse makes the light go out, and the leaking voltage problem is still there.
One though I had today was if there is a possibility that the printed circuit that is on the back of the cluster, and carries connections to all the indicators and the gas gauge, might be the problem. So, I pulled the GAUGE fuse, and the problem goes away. Looking at the wiring diagram, there are no obvious points where the leak could occur, but obviously somehow there is. Also, due to the low voltage, that might coincide with the voltage to the gas gauge. Without draining the tank to see if the voltage changes, I might try disconnecting the sending unit at the tank harness to see if that affects the problem. If it does, that would tend to point to the printed circuit, maybe, so I might go ahead and order one and change it just for ***** and giggles. I just don't know.
Was a beautiful day here, so I pulled the Nova out and took it for a 30 mile ride around the area. It runs great, sounds good, and rides pretty good. It is a little noisy inside with the windows down, but I can still turn the radio up and hear it just fine. I even got a couple thumbs up from other drivers, which makes you feel good. In May, the cruise-ins at the Essenhauis start again on Thursdays, so I can make it to some of them this year.
When I got back to the house, I drug out the hose, filled the wash bucket with soapy water, scrubbed off all the dust, and rinsed it off. After drying it of, it looked a lot better.
I also opened the hood and turned the valve off in the heater hose, I forgot to do it before I went for the ride, but it really didn't put out any noticeable heat with the controls set to cold.
And best of all, no leaks!
So, when I decide to pull the dash out, again, I'll post an update.
