B7100
/ B7100 #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
This is my beautiful wife standing next to a beautiful tractor that has less than 150 hrs on it.
It was sitting in the local kubota showroom.
I thought maybe some of you guys had owned this model tractor might like seeing it.
Too bad it doesn’t have the mower deck.
Assuming it could have had one
/ B7100 #2
That’s a snazzy looking tractor. TD says 1976-1985. Cool!
/ B7100 #3
I had one with a loader. It did not look anywhere near as good as that one. And it had about 2500 hours on it. I sold it to a mechanic at the dealer where I bought the BX23s. My wife has a B6100.
/ B7100 #4
My wife's B6100 started leaking coolant at the front of engine. I found the leak to be from the Dinamo mount. After 55 years the aluminum base corroded. Not an easy to replace part.
/ B7100 #5
One of the best tractor Kubota made,your going to like it. (y)
If you decided to get front loader remember there no power steering.
/ B7100 #6
Had more or less the same thing happening on a B7000. Machined a new aluminium fitting and had it welded. Worked alright but was tricky to weld for sure.
/ B7100 #7
Here's my 1978 B7100DT that I bought new, it has around 1200 hrs now. I leave my box blade on always, because of my arthritic spine I quit using my Woods RM48 and bought a zero turn mower.
I also use it for moving trailers. I put hydraulics on it so I can dump my CMI 4'x8' dump trailer. Once I had hydraulics on it I added on hydraulic top link for the box blade.
I also have 3pt forks, 12" single bottom plow and a 5' rear blade.
Over the years I've had 5 people that wanted to buy it. In the early 80's a couple of people would have given me $5k for it. I was lucky when I bought it my boss/owner of company was good friends with the tractor dealer and got me $500 off on the tractor, a lot of money then.
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61568)
2013 Freightliner...
UNUSED 30" QUICK ATTACH PALLET FORKS (A62130)
UNUSED 30" QUICK...
2015 BOBCAT T770 SKID STEER (A62129)
2015 BOBCAT T770...
2003 Ford F-250 Pickup Truck (A61568)
2003 Ford F-250...
2000 Mack RD688S Roll Off Truck, VIN # 1M2P267C7YM053032 (A61165)
2000 Mack RD688S...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
