I Won't Operate My Equipment in Wet Weather
   / I Won't Operate My Equipment in Wet Weather #31
   / I Won't Operate My Equipment in Wet Weather #32
I've been out in the rain on my cab tractor while moving dirt. If it's not a heavy storm, or if it's just a passing storm cell, I'll just turn on the wipers and keep working.
And that's what makes a cab worth the investment.
   / I Won't Operate My Equipment in Wet Weather #33
The EddieWalker approach works for me. The RFM works OK but needs a cleaning when the grass is juicy. Below is a link to what worked well on the Kubota. Somewhere I commented that on the Ford there's a small hole in the fan shroud that serves as an insertion point for the blow wands that make it very handy to reach the entire back side of the radiator without needing to work around the fan blades. Next time the Kubota needs cleaned I'll check if it has something like that. If not I'll carefully make a hole or two. a 1/2"" hole or two won't affect the cooling capacity.
Last week I did a good cleaning on the Ford's radiator along with a coolant flush 'n refill. For the latter I refilled / ran / drained with plain water a few times. Then after removing both radiator hoses, flushed it all and blew it out with a shop vac. Refilled with distilled water and antifreeze mix.
   / I Won't Operate My Equipment in Wet Weather #34
I have a radiator genie, but rarely see the need for it
   / I Won't Operate My Equipment in Wet Weather #35
I mean, this picture was only about 30 min worth of brush cutting to get to that point. In this case, it wasn't getting hot. I just knew with the stuff I was mowing, it was prone to happen very fast. It was just a matter of cleaning the screen too and it was good to go again.
A lot of people don't even realize that depending on what they're cutting, they may need to cleaning those radiators multiple times during the job. Then, they found the expensive way that they really should pay more attention to cleaning the radiator. I've seen others blame the manufacturers for using small radiators or some nonsense like that.
This is all part of owning and operating a tractor.
Im surprised there isnt a prescreen before the radiator. My kioti has one. It catches nearly all the crap before it gets trapped in rediator.
   / I Won't Operate My Equipment in Wet Weather #37
There is one. That's what all that cotton stuck too.
That time, I just parked the tractor so the wind would blow from the engine side to the front and tapped the screen. All that stuff came right out.
   / I Won't Operate My Equipment in Wet Weather #38
Ok, hard to tell by that picture.
   / I Won't Operate My Equipment in Wet Weather #39
My tractor hasn't seen rain/snow since I bought it new. Actually, none of my equipment or implements have.
This is NOT a slam, but I am curious. How do you do this? I end up having to go out and plow snow, dig out drainage ditches during storms, etc, etc.
I am pretty sure most, if not all of my equipment (Tractors, backhoe, implements, etc) has been out in just about every type of weather - I do try to head to the barn during severe thunderstorms/tornados though. šŸ¤£šŸ˜šŸ˜‚
   / I Won't Operate My Equipment in Wet Weather #40
My Kubota BX2680 was running warm when mowing in 90 degree plus Texas weather. I always clean the radiator screen before starting but it still was warmer than I thought that it should. I added wetter water and that helped a bit. Finally I noticed that the radiator was over half blocked by chaff that passed around the pre screen. I blew it clean and temps remained normal even in hot weather. I just added blowing out the radiator to the regular checks I make before using now.
New/Unused 14ft Bi-Parting Iron Gate (Cow Design) (A57454)
New/Unused 14ft...
14' Snowbox for Wheel Loader (A55272)
14' Snowbox for...
Hatz Diesel 6 Inch Water Pump (A57453)
Hatz Diesel 6 Inch...
2014 Polaris Ranger 800 (A57149)
2014 Polaris...
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
2019 CHEVROLET SILVERADO 11FT FLATBED (A59575)
2019 CHEVROLET...
