Opinions on Footwear
/ Opinions on Footwear #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
The collective opinions I've found here have never let me down in the past. Now I will see if this applies to footwear.
What's the go-to make and model of footwear that would meet my personal hang-ups, which are:
  • I put my boots on in the morning and I take them off at night. I can't stand having to take shoes off in the middle of the day, nor can I stand not wearing footwear
  • Steel toes are preferable
  • I work a white collar job (100% from home), but I can find myself outside excavating a new driveway, cutting up felled trees, and other such things on a whim in the middle of the day
  • I have a very visible role in church, which is a pretty casual place, but I wouldn't want to stomp around in super heavy-duty boots
  • Black is the ideal, neutral color
Picture something that's similar to the old Doc Marten boots before they went all junky. What I look for is akin to a modern day "LTZ" style Silverado HD. Beefy enough to do real work, but also appropriate for every day use, so not a dump truck, and also not a Toyota Camry.
/ Opinions on Footwear #2
I wear Keens to work every day here at the university and I deal with professionals all day every day. I find they're dressy enough but still boot enough. Probably the most comfortable boot I have ever worn. Once I get home, these Keens come off and Rocky Original Ride western work boots go on for the nitty gritty stuff.
/ Opinions on Footwear #4
I wore steel toed boots with an external metatarsal guard for about 20 years. The Redwing Shoe Mobile came to the factory twice a year.
My favorite were ankle high boots. Cool it the summer, warm enough in the winter and light enough to work a 12 hour day, walking or standing, inside or outside.
/ Opinions on Footwear #5
Redwing's tear up my feet. My employers for the past 20 years have had a boot program with redwing.
It's the sole design. I need something with arch support which redwing doesn't have.
Thankfully once I got a company credit card, I'm not stuck with having to go with redwing.
Took me a while to figure, but timberland pros have been the best for me and my feet.
Their linesman boots have extra arch support for people who climb. They just so happen to be perfect for the arches in my feet.
I had to buy expensive insoles for redwing boots and they helped, but didn't cure the aches in my feet.
/ Opinions on Footwear #6
My daughter got me a pair of these.
Yup!
no hard toes for me, they call them "crimp phalanges removers" in the EMT business.
/ Opinions on Footwear #7
These are hard to beat for durability and they don’t look huge on your feet.
/ Opinions on Footwear #8
Feet are different! Have you ever had to spend four ten hour days in ridged SKI BOOTS! I do that every winter. I also visit a favored boot fitter from time to time.
I have custom insoles (i.e. molded to my feet. And use "Super feet" in every work boot I wear.
My present "go to" around the shop and yard boot is a just above the ankle Timberland. Not a pricey boot.
/ Opinions on Footwear #9
eta
then there are the White boots. ;-)
Just looking , seems that the White brand is not what it used to be. I've only worn the logger, un-caulked! ;-)
Once you get used to a heel, it's hard to go back.
/ Opinions on Footwear #10
Yup!
Considering they are typically rated for 2,500 lbs+ if you've crushed them I think your probably in rough shape with or without.
/ Opinions on Footwear #11
eta
I have worn White’s boots for forestry work for 40+ years. The smoke jumper loggers are still handmade to fit individual feet and just as good as they used to be. They are the gold standard for fit and durability. I can wear them all day in rough country and never have sore feet. But, they are VERY expensive.
/ Opinions on Footwear #12
Lightweight, excellent traction, all day comfortable, warm, durable.
/ Opinions on Footwear #13
I generally prefer Ariat. Recently got a pair of Sureway 6" laceups and I like the way they fit and about $50 cheaper.
This time of year, I'll often wear my Skechers composite toe sneakers
/ Opinions on Footwear #14
eta
I've been thinking about a pair of White's but it won't be the logger style. The heels give me shin splints in short order.
/ Opinions on Footwear #15
Yup, I spent quite a few winters in ski boots. They didn't bother me though. I was a teenager.
/ Opinions on Footwear #16
So, I currently run 3 options that I like. Irish Setter pull on square toe, Non steel toe, that's anything that involves leaving the house, work, shopping, dinner, ect. I'm on my 3rd pair, and the consistently last me 18 months, which is the best of any boot I've had. 2nd choice, outside around the house/fishing/playing with dogs, some camo crocs, normally in 2wd. 3rd choice, water proof chore boots, Muck style, but these are Academys Magellen boots. Good for in chicken coop, hunting, mud, ect
/ Opinions on Footwear #17
I used to have a cheap pair of slip on, shoes, that i liked, wife Hated, and the issue was; i don't just wear socks around all day, so either, to slip these on for a minute, either your getting socks, or you're raw dogging it, and they get funky. Also, if they get wet, they get real funky
/ Opinions on Footwear #18
When you order your White’s don’t order a standard size. Treat yourself and get their measuring kit. Then you will get custom fit, but the price is still the same.
/ Opinions on Footwear #20
Walmart. $5.07
I wear them regardless of what I'm doing, from mucking a horse stable to attending a funeral.
Proud to be "the world's cheapest man" as I've been called.
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
16001 (A55853)
16001 (A55853)
2016 KOMATSU PC138USLC-10 EXCAVATOR (A62129)
2016 KOMATSU...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
40' 6 Door Shipping Container (A60352)
40' 6 Door...
2014 INTERNATIONAL PROSTAR 6X4 T/A  SLEEPER TRUCK TRACTOR (A59908)
2014 INTERNATIONAL...
