Who’s getting hay equipment prepped?
/ Who’s getting hay equipment prepped? #1
Hay Dude
Epic Contributor
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Axle seal
Baler loaded with twine/greasing.
/ Who’s getting hay equipment prepped? #2
Just changed all the chains on my baler last week. Bought some cutter parts, I'll do that when (if) it stops raining! No where near the level of maintenance you have to do though! Just built a 64x36 barn so plenty of new storage space too!
/ Who’s getting hay equipment prepped? #3
Been working on changing bearings on baler on and off for 2 weeks,after completion ran it for about 5 minutes and heard that dreaded sound of a different bearing going bad, so it is ordered and hopefully that will do it, glad it did it under the barn and not in the field as I would have never heard it from inside the cab of the tractor until I saw the smoke.
/ Who’s getting hay equipment prepped? #4
Be a while yet for me. Don't have to do a whole lot this year though...at least I hope not.
/ Who’s getting hay equipment prepped? #5
My equipment is much smaller and not as much for making a living but for putting food on the table. I do need to get in the barn and get my tractors and equipment started up, and ready to mow, bushhog, and till.
I'll be doing an extra garden this year, mostly for the kids.
It probably won't be today, though, I have inside stuff to do today.
/ Who’s getting hay equipment prepped? #6
Not yet but getting a parts list together for the baler and rakes.
/ Who’s getting hay equipment prepped? #7
Serviced my TC45DA cleaned out the fuel tank and replaced the loader valve as it quit lowering the bucket.
To do:
Build a new light setup for the ROPs
Add rear hydraulic valve
Installation of switches in permanent location
/ Who’s getting hay equipment prepped? #8
That's my biggest concern. A chain breaking was no big deal but bearings are another matter. I had a driven gear bearing go up in smoke year before last, scary stuff.
If only they'd made them grease-able, they'd last forever at the speed they turn. (old NH)
/ Who’s getting hay equipment prepped? #9
Good reminder-- everything needs oil changes and new filters. Whoops there goes several days ....
/ Who’s getting hay equipment prepped? #10
I'm clearing a place in the shop for a tire machine I ordered. Should be here in another week or so. I've had the Harbor Freight special for years but I'm getting too old (weak) for it. I went with air and electric this time. And it will sit under my gantry crane if I need help getting a tire on the table.
I was getting so flustered taking tires to the tire shop only to have them go flat the next day. The downtime is the worst. And I still have to dismount/remount the wheel myself to get it to the shop. It's catus abundance around here as well as Mesquite shedding its winter coat like a mangy dog. There're stickers everywhere!
Not a Coats, but it will do what I need.
/ Who’s getting hay equipment prepped? #11
I could write a book on having non-greasable bearings on a hay baler go out while baling hay, it's a wonder I haven't burnt a baler up in the field. I bought an IR thermometer to shoot the bearings in the hayfield after baling for a while but even that doesn't always work as well as you would think as when a bearing gets ready to go it goes.
I had 2 bearing fires on the same New Holland Roll Belt 450. Luckily, I caught them both before disaster.
/ Who’s getting hay equipment prepped? #14
Yeap. Already tilled and planted a field. My equipment is just really small.View attachment 3258686
Hah... you beat me to it! The only crop I'm hewing and harvesting here is lawn grass.
I did the maintenance on the zero turn over the Christmas break, as I usually tend to do, alongside the CUT and other OPE.
/ Who’s getting hay equipment prepped? #15
There is not a bearing on my Vermeer 504 that hasn't been replaced, the worst part is if I don't catch the ones on the roller tubes quick enough it flares the end of the tube and it's shot, and that's $750.00 a pop.
/ Who’s getting hay equipment prepped? #16
Bought some fuel for the tractor last week so I can mow again this weekend. Does that count?
/ Who’s getting hay equipment prepped? #17
I've had many bearings go. I think I've replaced every one on this baler now.
Last year one failed bearing turned into 7. The one that failed and smoked, two others that literally fell apart taking the machine apart to replace the first and 4 others that could hardly turn by hand.
/ Who’s getting hay equipment prepped? #18
Guess I already did start prep.
Got the baler control box mounted in new tractor.
Ordered spare bearings for new to me baler.
Did yard adjustments to hitch and rake height on new rotary rake.
Calculated how much twine and wrap to buy.
As of now I should just have to change oil & knives on the disc mower and grease everything.
/ Who’s getting hay equipment prepped? #19
Some bearings are easy, others make you wonder what a designer/engineer was thinking when they designed it.
/ Who’s getting hay equipment prepped? #20
I've done some an been back in the field in 30 minutes. Others 12 hours for one bearing. My personally favorite is not using the same bearing sizes on the majority of the machine.
2016 Ford F-350 4x4 Cab and Chassis Truck (A61568)
2016 Ford F-350...
NexTier Frac Manifold T/A Trailer (A60352)
NexTier Frac...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2016 Ford E-450 Passenger Bus (A61568)
2016 Ford E-450...
2015 Komatsu PC210LC-10 Hydraulic Excavator (A60352)
2015 Komatsu...
2006 JLG 2630ES ELECTRIC SCISSOR LIFT (A62129)
2006 JLG 2630ES...
