HawkinsHollow
Man that sure looks good! I hope it works! What a sweet little spot that is going to be when it fills up.
Unfortunately time is not on my side for a dock. My slopes have a pretty steep drop so should help with how far out I get growth. If it does fill and become a problem I'll be sure to post for a big helping of "I told you so"Now is the time to set your posts for a dock. One of my many mistakes was not doing this myself. Once my pond filled up, we fished from the shoreline, or in a rowboat.
Over the years, the shoreline grew more and more plants in the water, and it has become more challenging to enjoy fishing from the shoreline. I have to build a dock, or two, so we can enjoy fishing the pond without constantly getting caught in all the stuff in the water.
I guess the dock may be one thing I may want that I just don't realize yet. If I can get to it I may take the advise.I'm with Eddie on this - just set posts, leave the rest of the dock for later. I dug a footing and used 8" tube forms and left an anchor in the top when I last had my pond dry so it could be re-scooped - pretty minimal effort to set up the posts now, build the dock next year.
I guess an in-between measure would be to set some footings with only a small rise like 6" of a tube form above it.. perhaps also leave some rebar sticking up a foot and toss some pipe over it so nobody gets skeweredI guess the dock may be one thing I may want that I just don't realize yet. If I can get to it I may take the advise.
My terrain and surrounding hillsides kind of dictates the steepness. Not much of a choice on 3 of the sides on how steep it is. On the plus side the ctl and front brush cutter gives me about 8 ft of reach. If I end up with that problem it means it has filled up so I'll take it.Another mistake that I made was making the shoreline drop off too steep. I marked around the pond with red paint to show were the water would be when full, and then I graded the ground above the waterline so it would be easy to mow. Not much of an angle. Then on the water side, I wanted it to drop off as fast and as steep as I could to discourage reeds and other plants from growing there.
The thing I didn't think about was that the pond is only full for a short period of time, and as it drops, I have to deal with mowing the steep drop off. In places, this is very scary. Another thing I didn't realize was that the plants that grow in just a few inches to a foot of water will grow right up to the edge of the water and then take over the grass if not mowed constantly.
So now my challenge in life is mowing reeds at the edge of the water. Two years ago, I got a bigger tractor and a 12-foot batwing. This has made it a lot easier to get to the edge of the water and not have my tires any closer than I have to.
If I was doing it all over again, I would of made my shore line shallower, and easier to mow. The first five years was easy, but as Mother Nature takes over, she does what she wants!!!!
I've been thinking of getting a sickle bar mower for this reason, being able to cut off to the side a ways without a huge weight over thereAnother mistake that I made was making the shoreline drop off too steep. I marked around the pond with red paint to show were the water would be when full, and then I graded the ground above the waterline so it would be easy to mow. Not much of an angle. Then on the water side, I wanted it to drop off as fast and as steep as I could to discourage reeds and other plants from growing there.
I have one side that I would consider steeper than desired. It would require a large amount of dirt moved to build out the slope. I can climb it with my ctl so walkable in water, not sure. The rest I would consider a steep slope but nothing you couldn't walk out of.Dad has 3 ponds that were put in in the 1950's. Became natural streams in the cedar swamp. They all have a shallow edge in the water. Meaning a youngster that fell in could stand up and then get out. Too steep of an edge is about impossible to walk out of. Out about 6ft then the pond bottom drops off. Yes this leaves some potential for underwater growth, but has not been a problem. These ponds are all within easy access from his house. Jon
Just finished reworking it so dry at the moment. I understand the concern. I don't think there is anywhere that your going to be stuck should you fall in. May be on hands and knees in one spot but not going to be stuck with no way to exit.Is the bottom fairly clean? Dad's being spring fed and creek fed, gets a lot of silt. Which makes like a quick sand, loose your boot in stuff. BTDT. My prior post is to just point the fact of being able to get out of pond after falling in. Jon
