3d Printing for PT
/ 3d Printing for PT #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So got a printer over the holidays, really interesting to work with, learning a lot in my free time. Anyway, tinkered this up this AM when my usual spout bought the farm. Gen 1, has lot of kinks, but if you own a diesel PT you probably struggle with not soaking everything in oil. not sure why the PT has such a crap design but whatever... This worked, need to make some mods but I use it so infrequently we will see if I just use it till this one breaks or start putting in upgrades to the stl file.
/ 3d Printing for PT #2
Love my 3d printer but they still have a long way to go to be a consumer friendly tool.
If you are technical enough and don't mind the tinkering though it's amazing how they can provide value and fun.
Nice to see you were able to apply it to a PT improvement!
What are you working with? I have a x1c and it seems to me to be reasonably easy to run. For sure we are on a cusp of a change with these things.
/ 3d Printing for PT #4
I too have recently 3D printed tractor parts. In fact members asked if we can go into production for vintage parts no longer available! I'm only a 3yo in the CAD realm and my brother 15years.
FreeCAD tends to be an all around tool. It can even read in STL files, convert them back into CAD models for you to modify. Something the other systems don't do so well or can't.
Even full front grills!
Upgrade vintage glass fuses to mini-fuses,
45+ year vintage parts no longer available. just replicate and 3D print the front grill.
The flexible and semi-transparent materials can make replacement lenses no longer in production.
/ 3d Printing for PT #5
Need a replacement dash cluster? Take your dash to add in upgraded gauges becomes easy.
/ 3d Printing for PT #7
Never thought about steering bezel. Mine was never there. Good ideas
Provide the ID side, and I can tweak if to fit your machine. The side walls go down 19mm or 3/4-in.
I can take the Y for Yanmar off too.
Then post a FreeCAD file or STEP file for you to mess with, then 3D Print.
/ 3d Printing for PT #8
I bought a Prusa before Covid. It's the original Prusa, by Joesph Prusa, from a company called Prusa (the dude really loves his name). Initially, I didn't have much use for it—I had stopped playing with dolls several years earlier—so it sat unassembled for about a year and a half. Eventually, a mechanical engineer friend convinced me to set it up.
Once I began using the printer, I was genuinely amazed. The difference between additive and subtractive manufacturing, especially when creating organic shapes, was shocking. Recognizing its potential, I quickly moved on from the original Prusa (it was just too slow) and upgraded to a Bambu Lab X1C. Later, I added an A1. The A1, in particular, offers fantastic value—it shares the same bed size as the X1, is much quieter and the print quality is even better.
Throughout my life, only three tools have given me that profound "I don't know how I lived without this" feeling: the Fein Multimaster, the Bambu Lab X1, and the Power Trac PT-425.
/ 3d Printing for PT #9
One of my "techy" friends has been working on my Toro Workman. The cab door had been jerry rigged, and he got with one of his buddy's at work and they printed the parts to make the door latch mechanism operational again. Toro didn't make the cab, and the cab manufacturer is hard to deal with from a consumer standpoint. (as is Toro also). The fact that I have an operational door amazes me!
David from jax
/ 3d Printing for PT #10
The first time I saw anything about 3D printing was quite a while ago. Jay Leno did a segment with a guy about recreating missing/broken car marker lights and turn signal lights. They had some old car that was missing, say, the left rear turn signal lens. They removed the right turn signal lens, and put a 3D scanner on it. Once they got it scanned, they just mirrored the scan and produced a left turn signal. They then cast the 3D printed left signal in something to get a negative mold of it, then poured the amber resin in the mold. Ta da! New turn signal lens.
Pretty neat!
/ 3d Printing for PT #11
I have had the thought that PT should make the bottom of the tub with a solid plate that has an oil drain plug.........
/ 3d Printing for PT #13
Oil sight gauge on the side or maybe just listen by ear for oil sloshing.
/ 3d Printing for PT #14
Pretty neat!
Today, you can print in flexibly clear translucent material and make the lens directly, and in any color.
flexible TPU 95A, also offer better impact ability.
/ 3d Printing for PT #15
“Today, you can print in flexibly clear translucent material and make the lens directly, and in any color”
Maybe, You, can?
I know, I’m just a mere mortal with my 3d printer. No way, no how, could I print that complex curve, clear, smooth , headlight lens, that’s in those photos. I seriously doubt anyone else here could either.
Isn’t it mostly experimental at this point?
/ 3d Printing for PT #16
From that article....
"According to the report, the research showed that 3D printing was suitable for making prototypes, improving operational efficiency and shortening production times"
I don't think "we" are there yet. ;)
/ 3d Printing for PT #17
Those of you who are "creators," are you posting your creations anywhere online to be available to the rest of the world?
/ 3d Printing for PT #18
I have an Anycubic Photon resin printer and an Anycubic Kobra FDM printer. I have no problem running mine either but their are a lot of variables that can impact many aspects of printing.
For example, I can be running, in Ohio, the exact printer as someone in Alabama but if their house is more humid then mine we may not want the same profile settings to get the same results. Little things like that means some people have an out of the box working set-up and others don't and wonder why when things don't work as expected.
I'm a nerd and although I run my printers in the house, in a well controlled environment, I still tweaked a lot of settings to optimize my prints. These are the kind of things I think about when I say they have a long way to go to be consumer friendly.
If you had to fidget with your refrigerator settings to make sure your food didn't spoil you wouldn't be happy and I think for 3d printers to gain more acceptance they need to be that plug and play.
The fact we own Power Tracs already says something about our acceptance of non-standard equipment :)
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63689)
Magnolia Trailer...
2012 International Prostar (A63118)
2012 International...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
Landhonor 3Pt Potato Harvester (A66285)
Landhonor 3Pt...
Volvo VNM (A63689)
Volvo VNM (A63689)
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
