Source for QD male and female connectors for Mahindra 2638
   / Source for QD male and female connectors for Mahindra 2638 #1
Windsors
looking to buy
Besides ordering from Mahindra, I assume these are pretty standard and hoping for a source that will be cheaper. I'd like to make a pressure gage setup to test my FEL , etc hydraulic pressure. Thanks
   / Source for QD male and female connectors for Mahindra 2638 #2
Typical if you look closely the brand name and model number will probably be imprinted on sleeve of female QD.... With brand name and model number you can order exact same QD in after market or find a "generic" QD the will work same as what is on tractor now....
Why make pressure gauge when you can buy one ready to go for probably less $$$$
PDF file is cross reference to size and type of QD's
  • qd_sizechart.pdf
   / Source for QD male and female connectors for Mahindra 2638 #3
Don't know where you're located. Have you tried Tractor Supply or Rural King?
Thanks all for your comments. Will check them out.
2006 Dodge 3500 (A57148)
2006 Dodge 3500...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
2384 (A58376)
2384 (A58376)
SHOPBUILT PORTABLE WOOD SPLITTER (A52708)
SHOPBUILT PORTABLE...
2026 Hillcrest 14166SPT 22ft. 7 Ton T/A Tilt Deck Trailer (A56858)
2026 Hillcrest...
2005 DODGE RAM 1500 (A58214)
2005 DODGE RAM...
