Yanmar L70 - Heavy (lots) smoke
   / Yanmar L70 - Heavy (lots) smoke #1
i012783
Kubota SCL1000
Hi - I picked up a MEP-831A generator at a military auction. It arrived drained of fluids so I PM'd it and added new fuel/oil. It started up but had very heavy smoke coming out the exhaust. Here is a video of it when I started:
Just looking for ideas of troubleshooting? I'm mechanically inclined but never torn one of these down. Pull head and see damage? Any other ideas of what might cause this level of smoke?
Thanks!
   / Yanmar L70 - Heavy (lots) smoke #2
Two things . 1. sounds like it is over speeding or am I just hearing things? 2. Looks like oil burning off of something rather than exhaust smoke. I am unsure, can you confirm?
   / Yanmar L70 - Heavy (lots) smoke #3
It does sound like it is a bit erratic on the combustion, but the smoke looks like oil to me. I think that this is a 3600rpm generator, right?
   / Yanmar L70 - Heavy (lots) smoke #4
You say it was "drained of fluids", but maybe it had tipped over and filled the exhaust with oil before you bought it?
   / Yanmar L70 - Heavy (lots) smoke #5
All I saw was a video of someone overly excited. I couldn't tell what I was supposed to be looking at. Good image of the battery for a second. :ROFLMAO:
   / Yanmar L70 - Heavy (lots) smoke #6
Thanks!
Do ask in this section, they are very well versed in the Yanmar L-series engines,
   / Yanmar L70 - Heavy (lots) smoke #7
I agree it sounds like it’s over speeding. I would adjust the governor linkage to reduce the speed as my 1st step in diagnosing.
90cummins
   / Yanmar L70 - Heavy (lots) smoke #8
Was it stored for a while? Maybe the PO put some oil in the cylinder(s)?
   / Yanmar L70 - Heavy (lots) smoke #9
That is true Esp. Since it was stored for ?. The PO may have did it to keep the rings free. It's not lock down so that a big Plus!!
   / Yanmar L70 - Heavy (lots) smoke #10
If it is ex-DOD, the protocol is to drain everything, so that is unlikely. I think a perhaps bigger challenge is that almost anything could have been done or happened before the unit was scrapped. Sometimes the "non-repairable" cause is something easy for a civilian, sometimes less so, but I try to remember that even on the DOD side not everyone who touched the unit was an expert, and some units were used for training, e.g. stripping the generator all the way down to nuts and bolts and reassembling it.
@i012783 if you don't already have all of the technical manuals, I would suggest down loading them, especially the TM 9-6115-639-13&P manual, e.g.
I think that the good news is that the Yanmar engine is rock solid, and easy to work on.
All the best,
Peter
JOHN DEERE 630 DISC HARROW (A52708)
JOHN DEERE 630...
CASE IH 8R PLANTER (A52708)
CASE IH 8R PLANTER...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
KMC 4R TOOLBAR (A52708)
KMC 4R TOOLBAR...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
