CK20 Rear Remote Kit
/ CK20 Rear Remote Kit #1
timberwolf1
Kioti CK20H
I am looking for a CK20 rear remote kit for my 2006 CK20. I have contacted a few Kioti dealers with no luck. I have also looked all over the Internet with no success. Any suggestions or help that anyone could provide in locating one of these kits would be greatly appreciated.
Thank you!
/ CK20 Rear Remote Kit #2
Have you checked with Fit Rite Hydraulics? Brian Scudder is a skilled fabricator and very good guy. If he can't make up a kit for your tractor I'd be surprised.
/ CK20 Rear Remote Kit #3
Thank you!
My want to give these guys a call.. They are super helpful. Ask for Cody..
(not sure if there is an OEM kit as opposed to just buying the individual OEM parts)
/ CK20 Rear Remote Kit #5
I wouldn't bother with the stock remotes - been there, done that, and installed a 3 spool aftewards.. It's very easy to install a 2/3/4 spool on the ck20 and all later versions of this tractor - simply take the seat and cover off, you'll see the hard line that supplies the hydrualic flow, disconnect that, connect the hardline with another line to your spool of choice, connect the out port of the spool into where the hardline had previously connected, and then last connection is the bypass/low pressue line from the spool - this you connect to the low flow line that plumbs into the base of the hydrualic filler tube. (If your tractor doesn't have the small port on the bottom of said filler tube you can order that from Kioti, it's very costly and provides an easy clean way to get the low pressure line connected up.)
Then last thing to figure out is where to put all the ports! I fab'd up a plate that held them on my CK20s when I had that and now on the CK2510 with cab I just ran them out the lower part of the cab which was very convienent.
Hope that helps!
E.
/ CK20 Rear Remote Kit #6
Here's my post a long time ago figuring out how to add the spool to the CK20:
Hope that helps.
E.
Thank you for all of your replies! You have all been very helpful and have given me more to consider than I imagined. Not sure which direction I plan on going in yet, but I will add to this thread when I do.
/ CK20 Rear Remote Kit #9
I do not know if it is the same for a CK20 and CK-25/27/30/35, but I have a brand new never installed single rear remote kit Kioti PN T2165-A72000105 that I bought for my CK30H a number of years ago. I traded the tractor before I installed it. I am getting ready to post it for sale on eBay, but if it will work for you let me know and maybe we can work something out.
Jeff
Jeff
Thank you for the offer. I've looked into, and I don't believe it would fit.
/ CK20 Rear Remote Kit #11
Some pics showing my current setup after I moved the 3 port valve to the ck2510 (cab) to give you some ideas.
/ CK20 Rear Remote Kit #12
Some more..
/ CK20 Rear Remote Kit #13
I bought one for my 2005 CK20 hydro and never installed it. Sold the tractor but kept the kit (if I can find it!) I think it might be what you are looking for.LMK
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2014 Club Car Golf Cart (A62613)
2014 Club Car Golf...
2023 New Holland Powerstar 90 Tractor (A65579)
2023 New Holland...
