WinterDeere
Super Member
- Joined
- Sep 6, 2011
- Messages
- 6,098
- Location
- Philadelphia
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
Some quick numbers all from memory, so you may want to check me on this:And I wanted to ask you personally, is it convenient to use this mesh box from the water tank to transport firewood? To load, unload. You probably transport it with pallet forks. Does the tractor easily lift it, especially when the wood is damp or of high density? I'm thinking about purchasing one.
- The heaviest hardwoods, the white oaks and locusts of the woodburner's world, run around 65 lb/ft3 when green.
- The various state agencies of Weights and Measures usually figure a stacked cord of firewood around 85 ft3 of solid wood, so roughly 85/128 = 66% stacking efficiency. You're going to lose space in the corners and edges of the bin, unless bin dimensions are some perfect multiple of your cut length, but you're also probably going to endeavor to stack a bit more tightly and carefully in a small bin than when working by the cord. So let's say those two factors cancel, and your net stacking efficiency remains around 66%.
- The standard 275 gallon IBC tote cages are 40 x 48 x 46 inches, so 51 ft3 = 2193 lb. at 65 lb/ft3 and 66%. The 330 gallon version would then come out at 2631 lb.
- The cage itself weighs another 135 lb, bringing your totals up to 2328 to 2766 lb, respectively.
