Who still drives a stick in 2025?
   / Who still drives a stick in 2025?
I agree that the average vehicle lasts far longer now than in the "good old days " but when that period of parts and specialty tool support ends there is no way for an average back yard mechanic to keep them going. Up until the mid 80s everything on a car was essentially rebuildable, even things like an ignition module could be retrofitted with a different part or replaced with points. Once an ecm or body control module goes and isn't available that car is done.
Often just airbag deployment is enough to total a car and then add smog parts may no longer available for your 1976 car and your car isn’t a car anymore… just a pile of parts.
   / Who still drives a stick in 2025? #332
And you never went anywhere in one without tools, a set of coveralls and at the very least a spare belt.
Always with a copy of John Muir's book "How to keep your Volkswagen Alive a
Manual of Step-by-Step Procedures for the Compleat Idiot"​
fun and entertaining to read as well
   / Who still drives a stick in 2025? #333
Depends on which state, after 25years they don't require emissions testing.
   / Who still drives a stick in 2025? #334
There are a lot of aftermarket companies rebuilding electronics for nla parts.
At least for more popular models that have a following.
   / Who still drives a stick in 2025? #335
That car isn’t done. Certified shops fix them every day. Can you point to a case where modules aren’t available for modern vehicles?
   / Who still drives a stick in 2025? #336
And it’s not just cars, either. We had a 15 year old Bosch dishwasher (supposedly best dishwasher made) go down and the motherboard or main circuit board was no longer available.
Hello $1,500 for a new dishwasher. If the motherboard was still available, it would have been a few hundred.
I used to own a 2000 Case-IH 270 Magnum farm tractor. Great tractor, but the electric over hydraulic rear spool valves were no longer made as of years ago. All old stock and most boneyard tractors spools are gone. So if you drop a spool valve, you are SOL, unless you want to spend a lot more and retrofit new ones.
   / Who still drives a stick in 2025? #337
I don't know how popular this tractor was, but it's not reasonable to expect parts (especially oddball/proprietary ones like you describe) to be available forever. Goes with the territory if you want to keep old equipment running. Always been that way.
   / Who still drives a stick in 2025? #338
Magnums were very popular. Tractor was built in ‘99 or 2000. They quit making the spools by 2015.
Thats unreasonable. A 15 year old tractor is not “old”.
That’s the odd thing in that say for a Model T or Model A Ford total recreation are possible from new engine blocks to complete bodies… no electronics though…
17" Wheel Simulator, Front & Rear w/Hub Cap, Ford F-250 Chrome, 1 Set, Item # RZCMWC-9506 (A59076)
17" Wheel...
2013 Peterbilt 365 Tri Axle Altec AC38-127S 5 Section 38 Ton All Terrain Crane Truck (A55973)
2013 Peterbilt 365...
3PT HAY FORK (A52708)
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
JOHN DEERE GRILL GUARD FOR 5000 SERIES TRACTOR (A52708)
JOHN DEERE GRILL...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
