Tension roller on Woodland Mills WC88
   / Tension roller on Woodland Mills WC88 #21
Bump....Oz_Kioti, do you think your larger idler has improved belt life?
Wow - those posts were over three years ago! But I'm still using that same set of belts today, so yes, I believe the increased diameter idler has made a significant improvement to belt life.
The rest of the machine is thoughtfully designed, very well made, and functions nicely, so I'm still puzzled by their engineering decision to use such a small diameter OEM idler.
   / Tension roller on Woodland Mills WC88 #23
I just purchased a used WC88 off of FB Marketplace. The seller included a new set of belts, and said something like, "Here, you'll need these." I was surprised because on my old chipper (Bearcat) I've never changed the belt. Then when going over my new-to-me WC88 I was surprised at the radius of the belts at the idler, and at about that moment discovered the belts are coming apart on the inside. Found your old post when I searched on it.
   / Tension roller on Woodland Mills WC88 #24
Slow down the intake roller to the slowest speed and the chipper works much better. It will reduce the heavy tension on the belts, run better and last longer.
I run the chipper at about the lowest infeed speed. Very few feed issues as long as I don't feed "wishbone" style limbs into it.
I've been chipping (seasonally) about 5 years and never changed a belt.
   / Tension roller on Woodland Mills WC88 #25
I had and sold a Chinese chipper some years ago and never had a belt issue with it but I kept them fiddle string tight at all times and kept the pillow blocks well greased. Sold it for what I paid for it in about 2 hours on FBMP and I ran it on the back of one of my 90 horse Kubota's, which is why the base is so high up so I could run the pto driveline reasonably straight.
   / Tension roller on Woodland Mills WC88 #26
it is one of the reasons I chose the WC68 over the WC88. If ever the hydraulics went south I could just plumb the drive roller to my remote hydraulics and keep the flywheel going with the PTO shaft. but the pto drives the Pump on the WC88.
2012 International 4300 Reefer Truck (A57024)
2012 International...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
Husqvarna Z 248F 48in Zero Turn Mower (A55851)
Husqvarna Z 248F...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55852)
2004 Pierce Tilt...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
