Alternator replace with 10SI GM
/ Alternator replace with 10SI GM #1
RandyH79
Mahindra 3540
Hi, new to the forum. I have a Mahindra 3540 Shuttle Shift and recently the alternator gave up the ghost. The dealer wanted $800.00 for a new one so I put a GM 10SI 3 wire 105-amp alternator on it. As soon as the engine starts, it blows the 40-amp main fuse. Do I need to replace the 40-amp fuse with a 60 amp maybe because of the higher amp output or possibly put a resistor in line? Anyone with experience doing a swap to a higher output alternator? Thanks
/ Alternator replace with 10SI GM #2
Are you using the original voltage regulator or did you get a GM regulator as well? The original regulator may not be able to handle the new alternator.
/ Alternator replace with 10SI GM #3
The 10SI has a built-in regulator. That's what the SI or "System Intergrated" means. You have to wire it so as to Bypass the original voltage regulator. I hope you didn't smoke the Alternator. Its output is already DC and regulated. Below is one way to wire the alternator (there are several). It makes use of a charge/discharge light.
/ Alternator replace with 10SI GM #5
So, when you're sitting out in the middle of a field with a dead battery because the alternator belt broke, you wonder why you didn't wire in the idiot light. :ROFLMAO:
The "3-wire" SI can be wired without the light or as a "single wire" as well. The discharge Light comes in handy though.
Thanks for the replies and info y'all. Got it working. I made an adapter out of a blown fuse and hooked it to a 120 amp breaker. Everything works as should now no problems. I have ordered some 100 amp fuses to try and if it works, I'll use it instead of the 120 amp breaker. I'll let you know but it's working great now. Had to modify the existing mounting hardware and put the old pully on the new alternator using a spacer to keep the fan from rubbing against the housing. I'll try to post some pics tomorrow.
The 10SI has an internal one. Got it going . thanks
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
(2) New 26X9-14.5 severe duty batwing tires on 5-lug batwing rims, Coal Valley, IL (A65640)
(2) New 26X9-14.5...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
