Why won't my 3 point go down?
   / Why won't my 3 point go down? #1
tallyho8
Super Member
North of the Gulf of America, west of Westwego
Kubota L4400, Kubota ZD326
I bush hogged for a couple of hours on my L4400 and raised the bush hog up to move to a different location. When I pushed the right hand lever to let the bush hog down, it stayed up and won't move.
I am not familiar with the workings of the 3 point but looking at it the lever turns a shaft on the right side. I don't know if this shaft goes all the way through and comes out the other side but if it does, the shaft coming out the left side does not move when the shaft on the right side goes up or down. I took photos to try to show you what I am talking about.
Is the left hand shaft supposed to move with the right hand shaft? If so, why is it not moving? If not, what would make my bush hog stay up when I push the down lever?
Right hand side lever
Left hand side shaft
I will check that first thing in the morning. Also I will check the allen screw on the shaft to see if it may be loose and even though I see the outer part turning, if it is loose, the inner shaft may not be turning.
My Kioti has a knob below the seat that controls the 3PH decent speed. My feet sometimes bump it enough to close it, which prevents the 3PH from going down. If you have 'that' knob, see if it is closed.
You were right. It has been over 10 years since I touched that knob and forgot all about it. THANKS!!!!!
   / Why won't my 3 point go down? #6
"Why won't my 3-point go down?"
"Because it's married?" 🤪
Sorry... but it's funny how that works.
John Deere Gator (A53317)
John Deere Gator...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A60460)
2017 Chevrolet...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
