Marking / taging / labeling hydraulic lines the cheap way.
   / Marking / taging / labeling hydraulic lines the cheap way. #31
I have a .48" chunk/section of telephone network wire that I think came from an office building demo site.
It was handed to me many, many years ago when I hired on as mechanic for a paving contractor that had scrapers, blades, dozers, tractors, you name it. Every color combination in the world for cutting a length off and wrapping the ends of hydraulic lines and electrical connectors.
I have since learned from other mechanics that a collection of different colored fingernail polish works great too but surface has to be clean.
I don't like tie-wraps because I get cut on them all the time.
Everyone has their.own way.
   / Marking / taging / labeling hydraulic lines the cheap way. #32
I put colored zip ties on as well, with a second red tie on the cylinder return lines. Red for return felt easy to remember. So I have a blue, blue red, green, green red, brown, brown red. Makes it easy to hook implements up correctly the first time.
I have never thought about doing that, but I just did that to all my cordless battery chargers and plug ends. All my charges are on the same shelf, what a mess!šŸ˜‚šŸ˜‚šŸ‘šŸ»
   / Marking / taging / labeling hydraulic lines the cheap way. #33
The zip-ties fade in the sun and will completely oxidize and fall apart, the vinyl electrical marking tape seems to last much longer... maybe I'll paint them if any hobby shops still sell the little bottles of enamel.
I use paint pens, have had great luck with them.
I got the idea from tractor Mike!
   / Marking / taging / labeling hydraulic lines the cheap way. #34
That can only happen if you're cutting them wrong, like using traditional dual-bevel cutters. With flush-cut dykes, cutting up against the lock body, there's no sharp edge left to cut you, ever.
   / Marking / taging / labeling hydraulic lines the cheap way. #35
Spiral poultry bands:
Cheap, durable, come in many colors.
   / Marking / taging / labeling hydraulic lines the cheap way. #36
These are what I use and are the way to go in My opinion. The zips always rot off. Though they are not needed one one of mine as all the hoses clamp on as a unit so there is no way to mix them up.
   / Marking / taging / labeling hydraulic lines the cheap way. #37
   / Marking / taging / labeling hydraulic lines the cheap way. #38
Or use a lighter to melt the end blunt. Im not fllush enough to have flush cut Dykes. šŸ˜‰
   / Marking / taging / labeling hydraulic lines the cheap way. #39
Cow tags, you can write on them and they come in various colors.
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
JMR Work Forklift Basket (A56857)
JMR Work Forklift...
JOHNSON 5 1/2HP SEAHORSE OUTBOARD MOTOR (A58374)
JOHNSON 5 1/2HP...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52709)
2018 CATERPILLAR...
2016 Subaru Forester 2.5i Premium Sport Utility 4D W/ 201K Miles (A59225)
2016 Subaru...
2017 Ford Transit 250 Cargo Van with Lift (A56858)
2017 Ford Transit...
