Old Hitch Adaptor Identification? Pic Included
   / Old Hitch Adaptor Identification? Pic Included #1
frogblossum
Southeast Texas
Kubota L3400 HST-F
Hello!
I've had this quick hitch (attached pic) for many years but this weekend I lost the pin in the picture (arrow pointing to the pin).
I have no idea where I got these hitch adaptors and I'm hoping either someone can lead me to the name of the hitch and / or where I can get a new pin!
Any help is surely appreciated!!
Ellen
   / Old Hitch Adaptor Identification? Pic Included #2
Use Google lens to search the internet for a match.
   / Old Hitch Adaptor Identification? Pic Included #3
Ellen, I agree, Google Lens will help, but, you need a picture of just the hitch portion without the pin.
   / Old Hitch Adaptor Identification? Pic Included #5
It's a very early version of Carter's... New ones are straight pins. They might be able to help but I would suggest finding a machine shop, some one with a metal lathe to turn you a couple new ones. I assume you have one of the old pins (from the other side?) Let them copy the measurements.
   / Old Hitch Adaptor Identification? Pic Included #6
I'm not familiar with the hitch but it appears the pin is sized down where it goes though hitch. Is it possible to drill the hitch to accept a straight pin?
   / Old Hitch Adaptor Identification? Pic Included #7
Someone with a metal lathe could knock that out in a few minutes...
David from jax
   / Old Hitch Adaptor Identification? Pic Included #8
I don't think so, that old pin (I think) rests on top of the short "upright". The newer versions, the "shorter" upright is taller and the pin is drilled into that upright.
   / Old Hitch Adaptor Identification? Pic Included #9
The pin is the part he lost, and all it is...is a pin. The rounded off end might take a little more time, but using a piece of stock the size of the pin, turn it down to the step size, then turn down the second step size, then clamp it in a mill or a drill press and drill the cross hole to retain it in the quick hitch. A longer piece of stock would probably make it easier to hold in the lathe, so parting it off once the steps are done is the only other operation. I could do it in a half hour, and I am a truck driver who happens to own a lathe.
David from jax
   / Old Hitch Adaptor Identification? Pic Included #10
I would have two of those pins made, because now that you have figured out how to loose them, you will continue to do so!
David from jax
iDrive TDS-2010H...
2013 Godwin CD103M Towable Diesel Pump (A59228)
2013 Godwin CD103M...
John Deere 4600 (A53317)
John Deere 4600...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- DEMO UNIT (A56438)
Greenworks...
Blue Diamond 103709 (A53317)
Blue Diamond...
207275 (A52708)
207275 (A52708)
