Surprised that there are no trailer hitches with tongue weight indicators
   / Surprised that there are no trailer hitches with tongue weight indicators #1
ZiggyD
MF 2705E
Many scales use transducers that convert the mechanical force on a sensor into an electrical signal. The measurable electrical signal is then translated into weight units and displayed. I'm surprised there aren't trailer hitch mounts that have a similar sensor that'll give a reading of the tongue weight. A rectangular sensor inserted into the structural steel of the hitch can measure compression on the bottom and expansion on the top and output the readings to a display on the tongue. Tongue weight is an important safety aspect of towing and I'm surprised none of the big manufacturers implemented something similar.
Thanks for coming to my TED Talk...
   / Surprised that there are no trailer hitches with tongue weight indicators #3
I guess you did not look to hard for one.
I've seen the mechanical ones. They're too expensive and bulky for casual towing. Still surprised that there's no electronic solution for this.
   / Surprised that there are no trailer hitches with tongue weight indicators #8
While I can see that as a good way to keep weight off the back of the tow vehicle and back onto the trailer axels.
I can also see my idiot neighbor putting weight too far back and causing instability problems, and/or loading the trailer past capacity.
   / Surprised that there are no trailer hitches with tongue weight indicators #9
MISC LOT (A55745)
MISC LOT (A55745)
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A55852)
2016 Freightliner...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A55851)
1996 JLG Commander...
