scott_vt
Super Member
- Joined
- Oct 5, 2004
- Messages
- 7,716
- Location
- east wells,vt
- Tractor
- 1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
I turned 2 over, bottom looks like new, only stripe of where joist was.Good Evening Dennis ,
Dennis, nothing but hard work, if I don’t say so myself ! The Vermont deck is screwed down, it will be a bear ! I have a couple flat bars and a 3ft wrecking/crowbar ! A back belt should help a lot !![]()
Happy, that is one huge tank ! I’m guessing, 5000 gallons? Sounds like you will be using some gas to cut the ends out !
I never thought of that. I am going to have help cutting so that would be a good idea for another pair of hands. Thanks PG!!A sawzall with a good blade works as fast as a torch for cutting up tanks in my experience. Also much less chance of a fire or explosion caused by the previous contents.
Yep.A sawzall with a good blade works as fast as a torch for cutting up tanks in my experience. Also much less chance of a fire or explosion caused by the previous contents.
Yes, absolutely! The owner of the oil business that I drive for does exactly that ! Cuts the old oil tank in half with a sawzall and then cleans all the gunk out before bringing it to the scrap yard!A sawzall with a good blade works as fast as a torch for cutting up tanks in my experience
