Cutting back trail sides. Lane shark/sickle/flail?
   / Cutting back trail sides. Lane shark/sickle/flail? #11
DIY Version
   / Cutting back trail sides. Lane shark/sickle/flail? #12
It strikes me that a Tractor/Loader model would be more functional, and puts you farther way from falling branches.
   / Cutting back trail sides. Lane shark/sickle/flail? #13
Garlon 3A
   / Cutting back trail sides. Lane shark/sickle/flail? #14
Looking for recommendations on something for keeping the growth back. This is maintaining a few times a year, not creating trails. Mostly blackberry vine, some yaupon and pine branches that we get tired of slapping in the face when going by on an atv. Been doing it with a hedge trimmer on an ATV but have a couple miles to do and its tiring. Ive seen the lane shark and variations that look good at about $5k. Also seen a couple front mounted sickles like agrishield and samurai that are much cheaper and lighter. I like the idea of having something on the front to watch while doing it. Never used an offset flail, seen a couple videos using them vertically, but they dont seem to do a clean cut on small stuff from what it looked like, but never used one. Id think it would also be easier to see what im doing in front instead of behind me. While the sickle isnt the most robust of the 3, it is the cheapest and im thinking if i normally do it with a battery powered hedge trimmer, the sickle should be enough? Also guessing i can raise a front mounted sickle way higher than an offset flail on the rear. Tractor is a 55hp 2555 mahindra if that matters...and soon to be a TYM 574 which is essentially the same.
If it's an ATV trail, how high do you really need to trim?
I can cut up to 8' with my offset flail and T&T kit:
   / Cutting back trail sides. Lane shark/sickle/flail? #15
Do know this tree (yaupon) but if not a hardwood I think a sickle bar mower would work if you keep it cut at least once a year. If you have true hardwoods...oak I think could whip a bar cutter. If you look at "tractor time with tim" ttwt on youtube, he has a sickle mower on front end loader and it seem to work well.
i bought a used sickle bar mower last week. The person who had it said if it fits in the guard it will cut it. I listened but have no faith it would cut any hardwood or softwood of that diameter.
Well, I also have to mow it with the tractor thats 8' high, so like to keep it cut to probably 10' high so branches arent rubbing down the cab
   / Cutting back trail sides. Lane shark/sickle/flail? #17
The five blade trailblazer mounted on the three point hitch will serve you better and you
will be better able to cut long limbs that will eventually sag down and enter the lane.
   / Cutting back trail sides. Lane shark/sickle/flail? #18
I have longed for a similar solution since owning a tractor. Doesn't seem to be an easy, I mean cheap, solution.
   / Cutting back trail sides. Lane shark/sickle/flail? #19
I use a limb ninja. It looks like a cheap 48 inch brush cutter, but I was backing up and pulled up a 5 or 6 inch oak tree, and it didn't hurt it. It has been a tough little cutter.
   / Cutting back trail sides. Lane shark/sickle/flail? #20
If you want to trim 10' high, the bucket mounted Trailblazer sounds like just the ticket.
KENWORTH ROLLBACK TOW TRUCK (A57192)
KENWORTH ROLLBACK...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
John Deere 5055E (A53317)
John Deere 5055E...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
