Oxy/acet tank ownership transfer
/ Oxy/acet tank ownership transfer #41
I’ve never been asked for proof of ownership but I have receipts for hydro testing which is just added proof of needed and my tanks have my stenciled name in large font on each.
/ Oxy/acet tank ownership transfer #42
My question which I believe will largely answer your question for you. How many times when getting a “refill” (my very limited experience with various tanks has always been an exchange) have you bern asked about proof of ownership?
Never.
/ Oxy/acet tank ownership transfer #43
Something I don't have either. When they require hydro testing, my LWS stamps it on the bottle, most times below the collar.
/ Oxy/acet tank ownership transfer #44
Whatever changed with Airgas, they now could care less about lease or ownership, and just
exchange MT for Full. Some years back, very strict about leases or proof of ownership,
and if you brought in a bottle that wasn't on your account, you had 2 choices if you couldn't
produce paperwork. 1. Leave bottle on dock and it's now theirs. 2. Talk to the sheriff they'd
threaten to call. I attribute the current lack of enforcement to counter Luddites only really
interested in keeping their noses in their phones. It seems like full workload to have them
generate an invoice for an exchange. No complaints from me...
/ Oxy/acet tank ownership transfer #45
Airgas was the worst I think. I avoided them and had a semi-local outfit that would fill or exchange. I had one oxygen bottle that was odd sized and they only had one or two of that size to exchange so there were times when it had to be sent in for refill instead of exchange. I finally upsized it with a trade and fee. Now I go to a smaller place that had been very good about exchanging even if my bottles needed to be retested. Just paid for a fill. That company had since changed ownership and I haven't need gas since, so I guess in time I will find out their policy. Ha!
/ Oxy/acet tank ownership transfer #47
Mine too but having the receipt lends credence I own the bottle since I paid for the hydro.
/ Oxy/acet tank ownership transfer #48
Free Hydro is a great deal… couldn’t get that even when the plant super was a personal friend but hydro, new valve, paint and fill very reasonable… plus free home pickup and delivery!
/ Oxy/acet tank ownership transfer #49
I don't use my torches too often, usually just for heating tight nuts or cutting them off. I have switched from using acetylene to using propane, much less expensive and easy to swap out at most stores of all types, even some drug stores, plus I use the propane for grilling and running my dual fuel generator. I still have a small acetylene bottle, but I seldom use it, especially since I have a propane compatible cutting tip, that was a difficult find.
I don't have a pickup, just a cargo van, the last time I went to Airgas to swap out my oxygen bottle, they refused to do it, since I would be putting it into the van. Went down the street to another place, Victor I think, no problem there.
1Mech
actually propane tank refills are the same way around here, suppliers will not fill a tank if it's to be transported horizontally, must be vertical (State regs). not sure on welding tanks re: that issue.
/ Oxy/acet tank ownership transfer #51
Never have those issues here. In fact, I lay down all my bottles when transporting them to and from the compressor station. Only bottle that would be impacted by being horizontal is the dissolved acetylene bottle and once it's vertical in the welding cart and sitting for a few hours, it's all good again.
I transport all my empty and full bottles in the back of the pickup truck, laying down and blocked from rolling.
apparently the State Reg for propane bottle trans upright apparently has to do with safety hazard if tank's valve is damaged or broken off in transport horizontally. have no idea if aqua lung tanks are dealt with the same way, regards
/ Oxy/acet tank ownership transfer #53
I never transport ANY of my bottles, inert shielding gas, acetylene or oxygen without the protective overcover installed and screwed down tight. Just common sense at least in my view.
/ Oxy/acet tank ownership transfer #54
Funny because propane tanks have a safety collar and SCUBA tanks don't.... May be because propane is a flammable gas and SCUBA tanks only contain compressed air.....
/ Oxy/acet tank ownership transfer #55
Have no knowledge concerning SCUBA tanks at all, other than they must be filled with breathable gas, not commercial gas.
/ Oxy/acet tank ownership transfer #56
Not compressed air but breathable compressed air free of any pollutants.
The safety collar on welding bottles is really there as the mounting for the threaded cap.
/ Oxy/acet tank ownership transfer #57
1Mech
Yet you can exchange at the grocery store and self load your propane…
/ Oxy/acet tank ownership transfer #58
My MC bottles with Victor gauges and torch are too small to have protective caps…
About 25 years ago the trunk of a car was blown off by a leaking propane tank and the gas ignited… speculation was turning on the headlights caused ignition because the last thing the driver remembered was turning in the lights as it was getting dark.
As for compressed oxygen in a van there must be a low volume threshold otherwise every ambulance couldn’t transport oxygen.
I’m curious as all my medical gas is now delivered by a box truck with roll up door and lift gate… the company said it went to box for security…
Nitrous Oxide was being taken right off the truck.
not the grill portable type, but larger 100 lb (i believe) bottles
/ Oxy/acet tank ownership transfer #60
I have no use for small bottles. and don't have any. Run time for me is way too short. No medical gas here unless it's the natural kind that I pass regularly, much to my wife's chagrin.
