Do You Have a Tractor Shed/Barn?
   / Do You Have a Tractor Shed/Barn? #241
   / Do You Have a Tractor Shed/Barn? #242
My tractor, side by sides, and log splitter are soon loosing their little 23' x 24' garage because I'm putting my car inside it. But they're going in an out building that's about complete. It's barely insulated and not heated but it'll be dry and out of the sun. Just finished putting OSB on the walls and had the crew come back to put the ceiling up. Now waiting on the electrician to finish and garage doors which *should* be installed end of next week.
   / Do You Have a Tractor Shed/Barn? #244
Making progress: all 900+ shell bolts have been tightened, did final inside grading today, next is the end wall and door wall.
With 900+ bolts, I assume you're using something better than the stamped sheet metal wrench Ikea included in the kit? :p
   / Do You Have a Tractor Shed/Barn? #245
Ha ha, yes indeed. Actually it is a steel masters building, didn't include wrenches. I used a drill driver with sockets.:)
   / Do You Have a Tractor Shed/Barn? #246
I envy you people down south that can have a nice simple shelter like that and not have to worry FEET of snow every winter, LOL
This is from March 1st. I have to pull in forward or else the rops hits the rafter, even folded. Had to push my way out backwards with the box blade. Just about 2 feet of snow. Once I could turn around it was easy plowing.
   / Do You Have a Tractor Shed/Barn? #247
yes!
For three out of four....;-)
   / Do You Have a Tractor Shed/Barn? #248
This is the tractor shed, it was on the property when we purchased a few months ago.
And this is the shop we just had built, it's 48x32 w/12'6" ceiling, blown in insulation in attic and 2" closed cell foam on walls.
Haven't finished getting the shop setup yet, still have to move most of my tools, 2 post lift, and compressor from the old place.
There is also a garage at the house as well as a wood floored shed for the UTV and mower.
Sorry for the game cam pic, only one I had of the shop right now. I put it there because we haven't fully moved in yet and I like to know if anyone is messing around the shop, it also catches anyone coming in the driveway.
   / Do You Have a Tractor Shed/Barn? #250
Looks like that camera is going to be good enough to tell you there's an intruder, but maybe not good enough to make an identification?
Deere 310L (A53317)
Deere 310L (A53317)
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
VICOR HAY CUTTER (A58214)
VICOR HAY CUTTER...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
WACKER NEUSON RTSC3 TRENCH COMPACTOR (A52709)
WACKER NEUSON...
