   / Share Pics of People Hauling or Towing Something Wrong #22,242
   / Share Pics of People Hauling or Towing Something Wrong #22,243
A goldmine of Towing Wrong pics.
Example:
   / Share Pics of People Hauling or Towing Something Wrong #22,244
It is my neighbor
   / Share Pics of People Hauling or Towing Something Wrong #22,245
Example:
I see stuff like that everyday from local farms, and I honestly don't see a problem with it, as long as trailer brakes and emergency break-away are working (PA requires brakes on every axle). I am sure this guy is hauling that load just across the farm, or on local roads between field and storage, not at high speed on the interstate.
The only apparent danger is if the trailer brakes become disabled, that trailer is heavy enough to drag that truck backwards down a hill, given the obviously-frozen conditions. Then again, I've had more hydraulic brake line failures over the years on my pickup trucks driven in snow and salt, than electric brake failures on trailers.
In states that only require brakes on one axle of a pair, I guess this could be a much bigger danger, if all of the weight of the trailer isn't on the only axle with brakes. Imagine a tail-heavy trailer breaking away from the truck, with the only brakes on the front axle. In that case, the whole trailer is just going to freewheel away, with the break-away on only the front axle doing nearly nothing to stop the load. It's really surprising all states don't require brakes on all axles.
   / Share Pics of People Hauling or Towing Something Wrong #22,246
Illinois is like that. Trailers between 3000-5000lbs require brakes on 1 axle 5001+lbs require brakes on all axles. Not a big deal with the guys pulling larger trailers. The issue is with the utility tandem axle trailers with 3.5K axles, but either don't have brakes or brakes on 1 axle and licensed for 3K, but they haul way more weight than that.
   / Share Pics of People Hauling or Towing Something Wrong #22,248
Brakes on the front axle only would actually be the best case in that scenario. Much like with a tandem axle trailer with brakes only on the rear axle going forwards.
With a typical spring suspension, hitting the brakes makes the rear axle plant itself while lifting the front axle.
   / Share Pics of People Hauling or Towing Something Wrong #22,251
zoinks. What are people THINKING !!!
   / Share Pics of People Hauling or Towing Something Wrong #22,252
Same here, that is my neighbor and the next guy down the road and the next next next . . .
That reddit link is W I L D !
I'm used to getting 15 bales delivered on goose neck equipment trailer at a time. One stashed in the Goose neck frame, maybe 2 straps on the rear. Looks about normal to me and no flat ground in these parts.
Buy about 50 per year.
   / Share Pics of People Hauling or Towing Something Wrong #22,255
   / Share Pics of People Hauling or Towing Something Wrong #22,257
   / Share Pics of People Hauling or Towing Something Wrong #22,258
ha ha ha, an AMISH tow truck!
2461 (A58376)
2461 (A58376)
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 International Derrick Digger Truck (A55973)
2014 International...
