You Know You Are Old When
   / You Know You Are Old When #4,613
You don't realize it's a scam😳
   / You Know You Are Old When #4,615
Metamucil 3 times a day will keep you young.
   / You Know You Are Old When #4,617
I've never been a coffee drinker. I haven't tasted it for well over 50 years. For some reason, last Sunday, while out on a drive, I asked my wife if I could taste her coffee...
   / You Know You Are Old When #4,618
Interesting question. It'd take 20,000 miles of wire to hear even a 0.1 second delay, so you'd never hear anything like the delays you get out of some wireless solutions, using a hardwired system. A small phase distortion at higher frequencies takes much less delay though, so let's run the quick numbers on that:
If we assume you might hear phase distortion when one speaker is 10% (i.e. 30°) out of phase with another, and we assume primary (non-harmonic) tonal content is mostly below 1 kHz (e.g. open high string on violin is 660 Hz), then a 10% phase shift would always require a phase difference between speakers of more than 1ms/10 = 0.1 ms.
Light travels at 983,571,056 ft per second, and maybe up to sqr(2) slower than that over PVC-insulated matched-impedance cabling. Let's say 700E6 ft/s.
So, a 0.1 ms delay would require 70,000 feet of wire length difference between two speakers, to even hear it at 1 kHz. Longer for lower frequencies, e.g. A = 400 Hz above middle C yields 174,000 ft of cable length difference. Harmonics might be more easily distorted, at say 7000 feet of wire, but my system is less than 5% of that length... and how many can really even identify harmonic distortion by ear?
My speakers are all on cable runs of maybe 60 to 200 feet, so no problems with delay. Our bigger issue is actually attenuation causing differences in the volume projected from different speakers on the same volume control, due to long cable lengths. Speakers are a relatively low impedance, and thus draw a lot of current from a small voltage.
That big fat Monster Cable guys use in 10 foot lengths for their stereo speakers is a totally pointless marketing gimmick at 10 feet, but big O2-free wire gauges become very useful when trying to make your speakers sitting out at 200 feet project with similar volume to those at just 40 or 60 feet. If you've ever wondered why they make high-impedance speakers (16 ohms and more), this is probably one of the reasons.
I completely misread your post. I thought you had all those speakers connected wirelessly around your house. Looking back, your post says wired. I must have misinterpreted the "WiFi streaming" and thought that you were broadcasting to your speakers on WiFi.
   / You Know You Are Old When #4,619
lol... no worries. Yep, all speakers are wired to two amplifiers. The only WiFi involved is in streaming from our phones or tablets to these two amplifiers.
One amp that powers all of the outdoor speakers is connected to our network via WiFi, but in the same room as the primary gateway/router, and the other is connected via Ethernet to the same router. I suspect there might be a slight delay between the group of speakers on the indoor amp and the group of speakers on the outdoor amp, in those very rare cases we stream the same material to both, but I've never noticed. Usually, we are only using one or the other, or streaming different content for indoor/outdoor.
   / You Know You Are Old When #4,620
YKYO when you see your Dr. more frequently than your best friends. He's also on your speed dial.
Actually, both my wife and I are in better health than a lot of our social circle, including many who are younger than us. Annual checkups, and that's about it.
Not that I'm complaining mind you.
2014 VOLVO VNL DAYCAB (A58214)
2014 VOLVO VNL...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2010 Chevrolet Tahoe SUV (A56859)
2010 Chevrolet...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2009 Honda Pilot AWD SUV (A56859)
2009 Honda Pilot...
2019 DODGE RAM LARAMIE 5500 FLATBED (A58214)
2019 DODGE RAM...
