Offgrid Genset Transfer switch
/ Offgrid Genset Transfer switch
Same, but with overhead light turned off
This is my old FX inverters controlling the Honda generator
When finished, either system will be able to control MEP diesel generator via selection from switch at top. Of course appropriate breakers engaged, disengaged.
MEP needs batteries so not usable yet.
All generators are autostart
Other than gen selection and breakers, operation can be controlled via internet.
As for the receptacles
Left side are live, powered by inverter and provide power to my trickle chargers and overhead light.
Right side is powered by Honda generator and provides power for the exhaust fan to run when gen runs.
Soooo, almost done, but at least functional.
/ Offgrid Genset Transfer switch #24
Any issues sourcing hardware to your location in Hawaii?
Is off grid common in your area.
Any issues with permitting agencies?
I’ve thought about an in place installed generator in conjunction with my solar so as to avoid having to roll out the generator along with the power cords during outages…
My solar production stops when utility power is down.
Hardware availability can be mixed. For this project I bought everything online. My solar systems have been a mix, most locally sourced, but many of my replacement PV came from mainland. My Kohler genset was an online purchase but the Honda EU7000 was local. Yes, most of the neighborhood is offgrid as are many of my rural friends. Haven’t kept up with permitting and changing requirements. My initial system was fully permitted and a PITA, not bothered with my upgrades.
Sounds like you have grid tied solar, no batteries. Maybe adding a generator to the system will give you the capability to harvest solar when grid is out. The newer systems have capabilities I’m not familiar with.
/ Offgrid Genset Transfer switch #26
Solar not working when the grid goes down means you loose power like everyone else! I would think a battery backup of some sort would be a smart investment if the power goes out very often.
Not sure how adding a generator would allow you to harvest solar when the grid drops, but this topic is way over my head anyway!
David from jax
/ Offgrid Genset Transfer switch #27
All I know is the OP appears to have a complex system of electrification. Complexity breeds failure last time I checked. Me, I'll stick with utility electrification and genny backup with hard wired vacuum transfer switches. Been fine for over 15 years now.
/ Offgrid Genset Transfer switch #28
The utility with a generator backup doesn't really work in Hawaii. Too poor of transmission lines along with very uneven ground which causes landslides. The wind they get from Typhoons is also an issue, so while you have mainland power, flat ground with basically no wind, the O/P is working against a whole different situation. While yours might work for you, it doesn't and won't work for everyone else. The fact that you have been fine for 15 years just means somebody else is paying for your power system line upgrades or they aren't getting done, which means your system won't last. In a complete grid failure, just how long with that generator last? My next door neighbor had the same attitude and it learned that about a week was when he ran out of juice. He has since doubled his fuel capacity which means he can now go two weeks. What will you be doing after 2 months of now power?
David from jax
/ Offgrid Genset Transfer switch #29
Maybe I should have clairified my comment a but. My standby gensets (I have 2, 1 diesel and 1 propane and I own 3-500 gallon propane bottles so I have plenty to run the propane fired genny and the diesel one is plumbed to my 500 gallon farm tank. I know nothing about Hawaii except vacationing there a couple times. I know nothing about they provide baseload either. Do the utilize nuclear or coal or gas fired baseload generation and is it reliable or not? I have no idea. It (power) didn't seem an issue when we were there.
Other than everything being subtitled in Japanese, it all appeared pretty normal to me.
/ Offgrid Genset Transfer switch #30
We have been totally offgrid since 2005.
Are you offgrid because there are no transmission lines to your property or it is too costly to connect to them? When visiting my sister in law on Kauai I noticed how expensive gasoline and propane are. This makes me wonder about how much it costs you to run your generators. I'm just curious.
Thanks,
Eric
/ Offgrid Genset Transfer switch #31
Thanks,
Eric
Power rates in Hawaii aren't exactly cheap, $.37-$0.4+/kWh, plus the usual add-ons.
Hawaii has been moving away from fossil fuels, but demand has kept petroleum at about 77%. They did shut down their last coal fired a while back;
But, yes, fuel costs are high, as are power costs, favoring solar, but so many folks have solar already that HELCO requires batteries with solar in many areas, because the small grid(s) can't absorb all of the power.
All the best,
Peter
P.S. the Wikipedia entry on Hawaiian electricity is riddled with with dated or misstated information.
Thanks,
Eric
A mixed bag
Neighbor directly behind me has grid power. Would have been 3-4 poles to get it to mine, as well as permission. At the time, it penciled out pretty close. Wife and I reasoned that if we had power extended here the next property down could expect same and we end up with a view of power lines.
Gas, propane, and diesel all hover around $5/g. Since upgrading # of panels, batteries and my Radian system, i’m about 100 hours or less per year running generator, so around $500/yr. I used about 11300 kwh power last year. Guessing that would have been an easy $5k to the power company.
We use propane through the house for stove, hot water, dryer, need diesel for my tractor, gas for mower so no big deal.
/ Offgrid Genset Transfer switch #33
A mixed bag
So you really don't run your generator very much. I can see how that would work out in your favor. I wanted to get 3 phase power run to my place for the machine shop I was building. It would have required 5 new poles because three phase poles are taller than single phase poles where I live. I would have had to pay 1500 bucks per pole, and pay for the new wires, and the utility would have owned the poles and the wires. I ended buying a phase converter which served me very well for 25 years until I retired. It seems like you have done the most economical thing considering your situation.
Eric
/ Offgrid Genset Transfer switch #34
Is under-grounding of electric an option?
In WA everything to my place is underground… electric, comcast and phone.
It keeps the views and minimizes storm interruptions.
/ Offgrid Genset Transfer switch #35
We're underground here, too. Really cuts down on outages, in our heavily-forested corner of PA.
At least in our case, the underground run from Verizon (FiOS) was free, but it was less than 500 feet from the closest box to my front door. If etpm only needs 5 poles, their run is probably even shorter than mine.
/ Offgrid Genset Transfer switch #36
My power is all underground once it is on my property. The poles I would have had to buy were poles running down the street and one pole on my property and one on my neighbor's. The power runs down my street on a couple poles, then on the pole on my neighbor's property, then on the pole on my property, then crosses the road to another pole, then under the street back onto my property where it remains underground. Crazy. The phone is all underground. There is no Comcast running down my street and never will be. Not enough customers.
Eric
/ Offgrid Genset Transfer switch #37
The prudent way is to run utilities underground but it initially costs more in equipment and manpower than overhead on wooden poles so utility companies don't do it. They should in reality. Don't here but again should. Being independent companies, their profit margins paramount, not practical application, IOW poles are cheaper initially.
/ Offgrid Genset Transfer switch #38
...poles are cheaper initially.
Yeah that's definitely been the case for many years. But having watched PECO run all new underground lines in our neighborhood last year, I'm wondering how much that holds true today. They basically dig a hole every 100 - 200 feet, and just shoot the line thru the earth between holes. No more trenching, like the old days.
At some point, you would think the cost of the poles, pole hardware, and the cost of planting them has to be getting awful close to basically shooting wires thru the earth, in a trenchless model.
/ Offgrid Genset Transfer switch #39
We went through the pole thing on our up north property. Were going to build a home up there and Consumers quoted us a price to run power from the existing lines to where we wanted it on the property and it was 55 grand to set the poles and string the wires. We passed. The taxes on the property are already high enough so it stays as it is, hunting property only. I'd like to live there but not gonna happen. Closest to living there is taking the camper up in the summer and 'roughing it. Hunt time is the motel. Around here underground would be iffy with all the mature tree roots to deal with I presume. The issue around here is the Utility (DTE) don't keep up on trimming the trees so with almost every wind storm comes an outage because of limbs taking the wires down. If DTE just instituted a proper trimming program, there would be no issue.
/ Offgrid Genset Transfer switch #40
Depending on where the line is, there are trade offs between the longer lifetime of overhead wire compared to underground wire, vs the potentially maintenance costs of overhead wire (tree trimming, and pole/insulator inspections) vs lower maintenance costs, but higher costs of underground runs. At the end of the day, I suspect only the utility has the numbers for those trade offs, and new equipment or labor contractors could push things one way or the other.
Around here, capital investment is guaranteed a 10% ROI for utilities, labor just comes as a running cost. Hence the current push to underground wires at billion dollar prices in California. Warped would be a good adjective to use.
All the best,
Peter
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
2017 Bad Boy Outlaw XP 60in. Zero Turn Commercial Mower (A64553)
2017 Bad Boy...
2023 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2023 CATERPILLAR...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
