Talk me out of an excavator!
   / Talk me out of an excavator!
Another factor: I have a backhoe for the CK35, so can do most of the digging I may need, although slow
   / Talk me out of an excavator! #12
I have a two ton open canopy machine, a 6ton cab machine with Engcon and about to get a 3.5 or 4ton cab machine.
So no I’m not going to talk you out of it.
   / Talk me out of an excavator! #13
I like those takeuchi 15,000 machines on steel tracks.
   / Talk me out of an excavator! #14
I've gone back and forth on getting an excavator. My neighbor has hired people to work on his place with everything from 8 tones to 45 tones. The 8 ton machine seems to be pretty good at taking down trees and digging stumps, but he had a 15 ton machine there for a very long time, and it got a lot done, a lot faster. But when he decided to buy something, he talked to me about my backhoe, and decided that it was a lot more useful then an excavator.
For me, I have a simple 2 wheel drive, open station backhoe that I can take any sized tree out, cut it to size, and carry it with the grapple on the loader. I can haul a yard of dirt at a time, and it's great for back dragging an area to smooth it out. Having tires instead of tracks means it gets around faster without tearing up the ground.
The biggest negative that I have in getting an excavator is that it's terrible and moving material around. Once you dig up the tree, it sits there while you get something else to pick up the tree and haul it to the burn pile, or cut it into firwood. Once you dig the hole in the ground, you need something else to move the dirt to where you need it. There is nothing better at digging then an excavator, but there is also nothing worse at moving stuff around then an excavator. When my backhoe wears out, I'll but another one. Odds are very good that I'll never buy an excavator, even though I'd love to have one.
And I just thought of another great use for the backhoe. It's fantastic at pulling my other tractors and mowers out of the mud. Just connect a chain to the hoe bucket, and pull. Being able to drive the backhoe to where I'm stuck as fast as possible makes the entire process less painful.
   / Talk me out of an excavator! #15
The last time I had to clear a fence row I asked the neighbor to do it. A few minutes with his Deere 450D and the job was done. In return I help him with some firewood. It's a win/win for both of us.
   / Talk me out of an excavator! #17
   / Talk me out of an excavator! #18
I thought I didn't need one for years. I have 3 daughters, and none will even drive the cab tractor while I shovel dirt in the bucket. Because of no help I decided to buy a kx080 and I love it. It's just their inheritance.
Now, a backhoe sucks and one of those add on things for a tractor really sucks. I say get it if you can afford it.
   / Talk me out of an excavator! #19
Honestly for two smaller jobs that really arnt even a need to do I wouldnt get one.
I own a 3500lb machine have have dug house foundations out to septic systems. Cleaning up a pond bank or cutting underbrush is not really where a mini ex shines. There all about digging and getting in/out of tight spots.
I have cleaned up logging mess with mine on property i own but generaly that's just pileing tree tops as close to where they fell and burning them.
   / Talk me out of an excavator! #20
Backhoes don’t suck for dirt scooping, snowplowing, stuck equipment extracting, and roading from one job to another.
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
2016 CATERPILLAR 336FL EXCAVATOR (A52707)
2016 CATERPILLAR...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
