single action cylinder question(s)
/ single action cylinder question(s) #1
blenderbender
Member
Western Pa.
Kubota B 3000
I picked up a Chinese sickle bar mower that has a single action hydraulic cylinder, power up/gravity down. My Kubota tractor has a single set of rear remotes on a dual action control. I don't understand hydraulics nearly well enough, but I'm guessing this is a problem in terms of using this single action cylinder and I don't have a clue what my options might be other than swapping out for a dual acting cylinder. Any thoughts appreciated!
/ single action cylinder question(s) #2
Does your tractor have “float” option on the rear remotes? If yes you can use that feature or if not just plug the one hose into one of the quick disconnects. Pull back to raise, push forward to lower same as double acting. Yes lowering you will be at system relief for a few seconds but once you release the lever it will be ok.
/ single action cylinder question(s) #3
When lowering, being a dual acting valve, it will push fluid through the relief at max pressure on the non used port, which is usually bad if done for long periods of time. For a short run like this? It's perfectly fine.
I guess I can't say if it has a float option on the rear remotes. All I've ever used it for is to adjust the angle on back blade when plowing snow. The lever floats in the center position but I don't think that's what you mean.
I'm not certain what you mean by "short run". Thanks!
/ single action cylinder question(s) #6
I meant for a short time. Like lowering the sickle bar. Only a couple seconds, then the valve is back to neutral.
So, I'm guessing it doesn't matter which port I plug into, but that will determine if I push or pull the lever to lift the sickle bar?
/ single action cylinder question(s) #8
Yes. That's it.
/ single action cylinder question(s) #9
Yes. Basically. When the lever is at neutral position, in the middle, the cylinder isn’t moving, in or out.
To find out if you have a “float position” on the SCV, press the lever all the ways forward (or backwards) and see if it can “pop” forward just a little more to a detent position and stay there. This is another type of “neutral position”, where the cylinder can float in or out, without resistance, if the sickle bar is manually raised or lowered (or is following the contours of the ground) (i.e. “float”).
Gravity will lower the sickle bar to its lowered position when the lever is in float position. Knowing this, you should connect the hydraulic hose to the specific port such that moving the lever lowers the bar just before the lever hits the detent float position. Follow?
You don’t want to press the lever and have it raise raise the bar, then move lever more to the float detent position and the bar drops from some height.
Realistically, it’s not a big difference, but pushing the lever in one direction, shouldn’t have two outcomes (raise and then drop/float).
/ single action cylinder question(s) #10
Interesting! Can this limitation be "corrected" by running an extra line from the "non-used port (coupler)" back to the tank?
TIA, Dick
/ single action cylinder question(s) #11
TIA, Dick
Sure can. That's indeed one way to do it. A lot of valves, have a little lever that will do just that but internally.
You can also put a Tee fitting between the quick disconnect and valve, then a shutoff valve and a hose back to the tank. That way, it's always set up and ready to go.
/ single action cylinder question(s) #12
On single cylinder hydraulics, there should always be a hose run back to the tractor fill port. I was told not to just leave 1 hose unhooked. What Kioti did was have me add a connector to the hydraulic fill port on my tractor, than the second drain line went there. It still uses only 1 of the standard rear remotes. In my case it was power down rear post hole digger and float when PHD was raised. This port is the same thing they add if i was to install a backhoe.
/ single action cylinder question(s) #13
Unfortunately very few of the smaller tractors have a float option for any of the rear remotes.
One way to get it would be to use the loader joystick control as most of those do have a float position. A diverter valve could be plumbed into the loader circuit to use the loader lift/lower and float.
Most single action cylinders will only have one hose. The other end of the cylinder is normally just vented to atmosphere.
/ single action cylinder question(s) #14
the cylinder itself has 1 hose, but theres a diverter box before the cylinder with 3 connection points. (on mine)
/ single action cylinder question(s) #15
/ single action cylinder question(s) #16
I don't think there's anything to be concerned about here. My mid mount mower has a single acting lift cylinder with one hose. I attach it to the curl up loader port. To lower it I just push it in the down direction. It doesn't need to go into float.
/ single action cylinder question(s) #17
This is exactly what the PRV (pressure relief valve) is for, no issues whatsoever.
/ single action cylinder question(s) #18
What are you planning to use the sickle mower for ?
/ single action cylinder question(s) #19
TIA, Dick
You mean have a loose line with an open end that gets stuffed back into the hydraulic fill port?
Hmmm…well sure, that would prevent the relief valve operating for a few seconds when lowering / retracting the cylinder, but wouldn’t you the have ~3000psi of hydraulic fluid dumping out the end of an open hose?
I don’t know, is the GPM low enough, even if the pressure is high, that this isn’t scary or dangerous? Or is the pressure low as long as it doesn’t meet resistance? IDK.
/ single action cylinder question(s) #20
I wouldn’t want to be any where near it, even if I did anchor the end of the hose. I don’t know, is the GPM is low enough, even if the pressure is high, that this isn’t scary or dangerous? Or is the pressure low as long as it doesn’t meet resistance? IDK.
It's free flow going back to the tank. If there is no resistance in the flow path, there is no pressure.
Either way, I'm sure dicktill would do something more civilized than just shoving an hose through the fill port and having the fill port open to the elements.
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2017 Grand Design RV Toy Hauler Camper VIN # 573FS4334H1108024 (A61166)
2017 Grand Design...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
UNUSED RAYTREE RMSG29 - 29" HYD STUMP GRINDER (A62131)
UNUSED RAYTREE...
17601CFL (A59228)
17601CFL (A59228)
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63118)
Greenworks...
