Older scag sthm tram pump will fit in older 2425-2422 powertrac ask me how i know
   / Older scag sthm tram pump will fit in older 2425-2422 powertrac ask me how i know #1
Tchamp
Baldwin Georgia
Power trac PT-2422
Older scag sthm tram pump will fit in older twenty four twenty five and the twenty four twenty two powertrac.Ask me how i know…
   / Older scag sthm tram pump will fit in older 2425-2422 powertrac ask me how i know #4
It is the same pump but the scag turns opposite. Dont know if this will work or not. Has different plugs on both sides gonna have to do some research.
Good luck. If you can get the scab pump model, the configuration for the model should call out if it is unidirectional. AFAIK, some pumps are, some aren't.
All the best,
Peter
   / Older scag sthm tram pump will fit in older 2425-2422 powertrac ask me how i know #5
Is the charge pump built in or remote on that pump? If built in you would have to convert the charge to correct rotation. If not built in it might work as is.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
KUBOTA M6800 TRACTOR (A54756)
KUBOTA M6800...
(APPROX 320) 1X6X6 TONGUE & GROOVE PINE LUMBER (A54756)
(APPROX 320) 1X6X6...
2018 Ford Fusion Sedan (A55758)
2018 Ford Fusion...
2015V Chevrolet Equinox SUV (A53424)
2015V Chevrolet...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
