F.E. Myers Air Blast Orchard Sprayer Information
   / F.E. Myers Air Blast Orchard Sprayer Information
   / F.E. Myers Air Blast Orchard Sprayer Information #153
Something along these lines?
Those are really close, I am just NOT ready to drop $30 a piece for 18 of them.......I also like bringing back some old things back from the dead. (As you guys already know). A question I do have is the replacement diaphragm. I see them in a variety of lbs. Is the lbs the PSI that the check valve closes? So if the replacement diaphragm says 10 pounds, that means it closes at 10 psi?
   / F.E. Myers Air Blast Orchard Sprayer Information #155
I used lots of T-jet products and yes, it closes at 10 PSI. Cutting off at 10 PSI cuts off the dripple that would happen if there wasn't a check valve and the pressure slowly drops to zero. It also, gets up to pressure faster since there is a residual 10 psi in the line.
Update: Weather in the area was in the upper 40's last night so I was able to install the new piston cups and assembly. Someone on here, I believe Seven Gables, mentioned boiling them to soften them up. Worked great. I used my old Coleman camping stove, an old pot and dropped them in. They 'boiled' for about 5 minutes and I put them into well lubricated sleeves coated with Murphy's Tire Lube. They went right in.
The new Asian made units have arrived and they are much larger. Probably about an 1/8" larger. They MIGHT fit if I put them in, but they will probably require more HP to get them to spin. Worst case and in a pinch, I could turn them down on a lathe.
Update: I was able to use the sprayer for my first oil dormancy spray this past weekend. Worked great. It took a little doing to get the nozzle rate dialed in. I had the best luck with TeeJet orifice discs D3 at waist height, D2 higher up. I had to take the Cone Jet nozzles out due to using a 100 nozzle strainers and them getting plugged up in short order. A 25 mesh and the disc orifice was better. There is a bronze 4x6 pre-pump filter, holes are about 1/16” in diameter. That lets a lot of fines through the system. I would like to add a 150 micron sock around the bronze mesh. Is that a “no-no”? I have a feeling that it will clear up over time, but I would like to catch it before it runs through the pump and the nozzles.
   / F.E. Myers Air Blast Orchard Sprayer Information #158
Pretty typical for the first spray with a older sprayer that’s sat for years to plug filters and nozzles. I think you’re best option is to just keep flushing water through the entire system with the nozzles removed.
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
CATERPILLAR 931E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 931E...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
