Looking for a TYM BT200
/ Looking for a TYM BT200 #2
I’m looking for a TYM bt200 backhoe attachment to fit my 2010 TYM 293hst.
If I were looking for a backhoe to fit T233/T273/T293, (all share the same chassis, transmission etc. with different Mitsubishi engines and wheel/tire sizes), I'd talk to the closest dealer and see if they will let you crawl around under a T25 with the TX2000 loader installed, and measure things.
Perusing the parts manuals for my T233/T273/T293 and the T25, it seems there is a huge overlap of parts between them and the T25. Axles, transmission internals, the rear remote kits, etc., are the same. The TX2000 loader even seems to be the same. So, the TB65 backhoe for the T25 may be a bolt on, or very close. The subframe mounts for the TB65 backhoe share bolts with the mounts for the TX2000 loader. So, the chances are good.
If the dealer thinks you might buy the backhoe from them, they might even help you measure things.
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
Yale GLP070VXE 6,500lb Propane Forklift (A61572)
Yale GLP070VXE...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
JCT Skid Steer Auger Set (A64047)
JCT Skid Steer...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
