Yanmar F535D Axle
/ Yanmar F535D Axle #1
Tatortractor
Idaho
Yanmar F535D
Hello! Looking for some help sourcing a couple of rear axle shafts. I had no power to the back wheels so I am assuming the other axle looks the same as this one. 😬
/ Yanmar F535D Axle #2
Hello! Looking for some help sourcing a couple of rear axle shafts. I had no power to the back wheels so I am assuming the other axle looks the same as this one. 😬View attachment 2699810
Sorry, can't help with sourcing parts but you may only need to repair one side. Because of the differential if one wheel spins the other stays stationary unless you engage the differential lock.
If it were me I would fix the obvious broken side and then see if everything works as it should before pulling apart the other side.
I hope this helps.. Best of luck!!!
/ Yanmar F535D Axle
well truth be told when I bought the tractor I noticed only one rear wheel would spin so I would utilize the diff lock probable more than I should. So while pushing snow I decided to unlock the brakes for each side and force the wheel that was spinning to not and that’s when I lost all rear wheel power. That leads me to believe they are both broken….
/ Yanmar F535D Axle #4
A brake lockup could do that, too.
Have you tried to cross reference your tractor with other Yanmar models and even some John Deere machines ?
/ Yanmar F535D Axle #5
Sounds to me as though you have a different issue in the rear end as well. If the other axle was sheered like this one you would not be able to move at all without the differential lock being engaged all the time. We would need more information as to what would happen when driver inputs were given to brakes and diff lock in order to potentially figure out whats going on.
Just trying to help.
/ Yanmar F535D Axle
I’ll check into that. Any ideas where I can find that info? I’ve read that the F435 is similar but I’m not sure
/ Yanmar F535D Axle
I didn’t realize the 4wd was just a switch on the dash so when I purchased the tractor they had it it 4wd so it seemed like it worked fine (shame on me for not doing my due diligence)
/ Yanmar F535D Axle
Update: turns out all I need is this intermediate shaft. Trying every source I have. Any input would be great.
/ Yanmar F535D Axle #9
Saw you had a yanmar f535. Any chance you have any manuals for that? My f535 has front 4x4 not working. If I lift front tires off the ground in reverse, or back drag, left tire turns ,right tire doesn't move.
/ Yanmar F535D Axle
Here is what I have. It’s in Japanese so I have to use chat GPT to convert the page I need to English. Hope it helps @jcsam200
  • YANMAR F395 F475 F535 F605 OPERATIONS MANUAL ON03-00864.pdf
/ Yanmar F535D Axle
Update! I had a machine shop fab new axles and it’s back together and works like a champ. I now have the ability to have them made if anyone out there has this same issue. Let me know.
UNUSED WOLVERINE SB-12-72W 72" HYD SCREENING BKT (A62131)
UNUSED WOLVERINE...
2020 Chevrolet Tahoe SUV (A61569)
2020 Chevrolet...
2012 Great Dane 53ft. T/A Reefer Trailer (A61568)
2012 Great Dane...
UNUSED WOLVERINE MAD-12-12D 12" MINI HYD AUGER (A62131)
UNUSED WOLVERINE...
New/Unused AGT Quick Attach Auger with Three Bits (A61166)
New/Unused AGT...
2015 Dodge Journey SXT AWD SUV (A61569)
2015 Dodge Journey...
