What is some of your Pet Peeve's
   / What is some of your Pet Peeve's #1,853
Sometimes the pits send their owners to the hospital.
As a property manager forbidding companion animals is a quick way to run afoul of the law…
So basically a doctors note supersedes the rental agreement.
Some are encouraged to be anything but friendly…
With legal marijuana the dog of choice are pits.
   / What is some of your Pet Peeve's #1,854
This is a big peeve of mine. Some people really do need a dog. Yet the current status makes it harder for those who legitimately need one.
   / What is some of your Pet Peeve's #1,855
My peeve has been pet cans with a pull tab top. Occasionally the tab snaps off but worse yet is top off leaves a razor sharp 1/4" edge around can. It's very hard getting food out and we had a cat years ago with a bleeding tongue from getting food left in can out. Tongue healed eventually but you'd think manufacturers could come up with a better design.
Maybe they should all switch to plastic bowl with foil top.
   / What is some of your Pet Peeve's #1,856
...we had a cat years ago with a bleeding tongue from getting food left in can out. Tongue healed eventually but you'd think manufacturers could come up with a better design.
I did the very same thing to myself last weekend, not my tongue in cat food, but my finger in a grease gun tube. They use the same pull tab design on the larger 14 oz. tubes.
Full story: I had just gotten the last shot I was gonna get out of my 14 oz. grease gun, greasing spindles on the mower, and set it aside to change the cartridge before putting it away. Then I was working on chainsaws next, and when I went to grease a sprocket nose bar, I noticed the little Oregon push greaser I use for greasing nose sprockets was also empty.
"No problem," I think, the amount of leftover grease you throw away with each of those 14 oz. tubes is probably just enough to fill the Oregon push greaser. So, I unscrew the top from the big grease gun and swipe my finger around the inside of the end of the tube to collect up a big glob of the stuff to tuck into the Oregon greaser. Wow, does that semi-sharp burr of aluminum left by tearing off one of those lids do a number on a finger! I'm not sure if grease in the cut helped or hurt, but it healed quick enough.
   / What is some of your Pet Peeve's #1,857
Ouch!
I've done that too. There should be a better design. There are "pouches" for food, but squeezing it out leaves some. Maybe I'm the only one that cuts the end off of toothpaste tube when it's supposedly empty but still a lot left inside.
   / What is some of your Pet Peeve's #1,859
Or grease guns in general. Almost impossible to replace a cartridge without getting covered with grease. The old tube always seems to stick in the cylinder & putting it all back together is a general PITA, especially with your hands all greasy. As Fuddy noted, there ought to be a better design.
Gotta say, a lock & lube coupler sure does make using it way easier & cleaner! (y)
Here is another peeve of mine; autocorrect.
I changed "piece" to "peeve" twice, yet it still posted wrong
Not just autocorrect, but predictive typing too. I don't have a smartphone so I don't know if either "feature" can be disabled on one, but both are the first things I turn off in a browser or webmail.
   / What is some of your Pet Peeve's #1,860
Depends on your perspective. As someone who doesn't particularly like dogs, it seems every business is going overboard trying to be "dog friendly". I miss the days when you could go to a restaurant, supermarket or even work without someone feeling they need to have their dog with them.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A58018)
2014 REITNOUER...
2019 Berky Weedo Amphi King 6450 Amphibious Workboat (A56857)
2019 Berky Weedo...
KOMATSU PC138US-10 EXCAVATOR (A52709)
KOMATSU PC138US-10...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2016 Make...
(2) METAL & WOOD STORAGE RACKS (A52708)
(2) METAL & WOOD...
