Where do you park your tractor when not in use, inside/outside/Covered outside?
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #71
Years ago I saw a photo of a subcompact tractor in someone's living room; it was probably an add, and I think it was a Yanmar or Kioti.
Anyhow, I've spent days looking for it with no success, intending to add the caption 'If you're cold, they're cold, let them inside."
That would have been funny...
Was it the "Hoover" ??
manvacuuming-jpg.4840
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #73
The first few years it lived under a tarp. I felt sorry for it so I added a lean to and that's where it lives now.
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #74
My tractor will be getting a new home. Two dead trees blew down on my old pole barn. I had the tractor down at the house, in my garage during all the snow N ice at the time, so I didn't have to walk ¼-mile to the old pole barn in snow and 10° temps.
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #75
Will the new pole barn be closer to the house?
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #76
In one of the barns. Dirt floors so it gets dusty, but keeps the sun off of everything.
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #78
I put my 3010 under a canopy all year round, I drive it into the garage only if it needs to be serviced in winter (if it's very cold).
   / Where do you park your tractor when not in use, inside/outside/Covered outside? #79
All 4 are under cover. All exposed to cold, none are heated.
7 1/2 HP ELECTRIC MOTOR & BOOSTER PUMP (A58374)
7 1/2 HP ELECTRIC...
2008 FORD F-750 SUPER DUTY (A58214)
2008 FORD F-750...
2023 PITTS LB35-33CS LOWBOY TRAILER (A58018)
2023 PITTS...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
